What stroker to go with?
Old Dec 26, 2007 | 10:57 AM
mongoose_ss's Avatar
Default What stroker to go with?
Just got the ultimate X-Mas gift a ohio forcedinduction turbo kit from my wife and was wondering what stroker to purchase for a 6.0 iron block with some 317 heads. I never really hear anyone purchasing a stoker kit from eagle or callies. Is it cheaper to buy the parts separate? I want a 408 that is able to put out 1000 to the wheels. thanks
Old Dec 26, 2007 | 11:15 AM
LS2Camaro's Avatar
got a Callies Kit, cant go wrong, they are very reliable. It is cheaper most of the time to get the kit than purchasing them separately. cant go wrong with one of these kits from a reputable sponsor on this site http://www.ls1speed.com/cont.cfm?cid=C0000184
Old Dec 26, 2007 | 11:31 AM
turbo'd stang's Avatar
I would try to use someone that is local to you..or that you can drive to. HKE is in Houston and does good work. We've used him for several motors and they have all been fine. No oil pressure problems!
Old Dec 26, 2007 | 11:35 AM
LS2Camaro's Avatar
To give you a list of what my stroker kit came with, and is capable of putting down 1000 to the wheels, here it is:
Callies Forged crank 4"
Callies Compstar 6.125 Connecting rods
Clevite and Federal Mogul rod bearings
Plasma moly ring set
Mahle forged Pistons 32cc
Old Dec 26, 2007 | 11:36 AM
LS2Camaro's Avatar
Here is also another good kit from Wheel to Wheel, another very good known sponsor on this site. This kit claims to be able to hold 1500hp
http://www.w2wpowertrain.com/pc-69-3...plication.aspx
Old Dec 26, 2007 | 12:22 PM
What is your callies rotating assembly rated at?
Old Dec 26, 2007 | 12:42 PM
LS2Camaro's Avatar
More than 1000rwhp, I can tell you that much. Each part came highly recommended for my turbo Application.
Old Dec 26, 2007 | 12:45 PM
LS2Camaro's Avatar
I would give one of those sponsors or Bob at EPP a call, tell him your goals and he can tell you exactly what would be best for your application.
Old Dec 26, 2007 | 02:29 PM
BLNLS1/RX7's Avatar
Callies all the way.704RWHP and still running strong.
Old Dec 27, 2007 | 03:41 AM
EPP's Avatar
EPP
We use Callies Compstar, Callies Dragonslayer and Callies Racemaster crankshafts on our builds, have not had problems with any of them. We use Callies Compstar connectings rods on most of our builds and never have had a problem with them either. For pistons we usually go with Diamond, for rings we use Total Seal. Bob
Old Dec 27, 2007 | 05:46 AM
Websy21's Avatar
Callies Dragonslayer here too
Old Dec 27, 2007 | 08:25 AM
Bob Sent PM
Old Dec 27, 2007 | 09:49 AM
52172's Avatar
what a bitchen wife man!!!! Tell her I said she is one in a million.
Old Dec 27, 2007 | 10:02 AM
ABeasst's Avatar
I'm running a lunati crank with no problems.
Old Dec 27, 2007 | 11:45 AM
Is Anyone running a eagle stroker kit?
Old Dec 27, 2007 | 05:45 PM
red beast's Avatar
I have an eagle crank and run callies rods....I have friends that run the whole kit with no problems and I believe they are rated to 1k also.....
Old Dec 27, 2007 | 07:17 PM
VINCE's Avatar
Shorty Director
Mostly Callies here except the Diamond pistons..
Old Dec 27, 2007 | 09:11 PM
Does anyone know if the Howards I-beam rods lighter than the callies or eagle?
Old Dec 27, 2007 | 09:35 PM
52172's Avatar
weight doesn't really matter when your under BOOST its all about strength and the eagle **** is plenty strong when you talk to everyone that uses it.
Old Dec 27, 2007 | 10:11 PM
Tom@SpeedInc's Avatar
we also sell our well proven boost 6.0 motors for $3399
Includes Eagle H beam rods with ARP rod bolts
Diamond -15cc pistons/ plasma moly ring set/Clevite bearings.
no core charge
Boost prepped 403 Iron shortblock $4350
Compstar rotating assembly with Diamond pistons -15cc
L92 416ci shortblock $4850
same parts as above, L92 aluminum block
