pcv system
Old Jan 10, 2008 | 04:15 PM
383ls1blazer's Avatar
Default pcv system
hey whats up guys for my pcv system im running 10 an lines from the stock valvecovers to a catchcan with breather.
i need to know where i should drill the holes for the 10an the further back i could drill them the better. also is there any other modification i need to do to the stock covers besides plug the old holes?
also do u guys think i should add to the pcv system something that sucks out the gas when the system is under a vacuum?(like a line that connects from the valvecover to the tb with an oil seperator and checkvalve) or is what i have enough.
thanks guys
Old Jan 11, 2008 | 01:18 AM
bump
need to know this
Old Jan 11, 2008 | 02:39 PM
ls1290's Avatar
Dumb Ass Vette Moderator
Use the search Luke..... This topic has been cover numerous times in this section and the external Gen III.
Keith
Old Jan 11, 2008 | 03:30 PM
i searched but nobody really modifies the stock covers i don't know if there is any special place to drill the holes my in tuition tell me no it doesn't matter but im not sure.
and for the other stuff ur right i shouldn't be asking lol i just wanted to here the answer some reassurance
Old Jan 11, 2008 | 03:37 PM
Websy21's Avatar
No wonder mods get pissed off and the threads so fast. All you had to do is scroll down to the bottom of this page you posted in. There was a guy with the same concern just the other day and dug this thread up for him, so I guess I should do the same for you. All the info you need is in here. Try not to bug MM too much or he's gonna start sending me hate pm's Just kidding Dave, you are a good sport. If only I could help out as much people as you have
https://ls1tech.com/forums/forced-induction/517372-my-fi-pcv-crank-vac-system.html
Old Jan 11, 2008 | 04:01 PM
i have read that thread before but it doesn't mention anything about where to drill the holes into the valve covers i think im just going to drill them where i want
Old Jan 11, 2008 | 05:25 PM
MECHAM's Avatar
this is going to be my new setup.
tapping both valve covers with -10 lines..to a air filtered catch can..and suction to the air filter side.
u can tap them in the back or front. the shop that works on my car has done this with a vette tapped in with the good stainless hoses but im going cheapie with rubber hoses but mine is mounted below where its not visible to the public.
Old Jan 11, 2008 | 06:04 PM
so u run suction from the can from the turbo inlet? that seems like a good idea you wouldn't need any checkvalves of anything it seems and u would constantly be pulling a vacuum. i was going to do exactly what u did but not run and suction on the can but i think i will change my setup. one reason i am scared to run suction from the turbo is becuase i don't run any piping from my turbo inlet only a filter and when i race i don't plan on using a filter only a net. is there a simple solution?
Old Jan 11, 2008 | 09:27 PM
MECHAM's Avatar
i have the ls6 pcv with a check valve to the intake manifold
its sumthing like this below...
instead of using the valve nipples.
just make it a tapped line -10
add a air filter to the catch can..i think its the big moroso one
