I need advice on my next setup..
If your target is 800RWHP or under I think the block you have now with a good rod will be fine.
A D1SC "should" be enough blower for you but you may want to consider a F1.
With the right intercooler/aftercooler or water/alky injection, blower ported heads, headstuds, and good gaskets you should be able to run 20#'s on 110unleaded.
(~12#'s on 94 octane)
That should give you 9's@140-145mph in the 1/4 with a good trans and decent raceweight.
You need to take a ride in a car that does 140-150mph in the 1/4. It is absolutely crazy
If he is shooting for 750-800RWHP then of course he'll need fully custom fuel system, FAST or some other management.
He can run about 600RWHP no problem with the factory PCM and 50# injectors with LS1 edit. Have to scale the MAF and watching fueling past Maxed MAF reading carefully but it can be done
Cheers,
Chris
ps- I agree a blower would be easier to tune.
Big front mount intercooler, water/alky setup and a D1SC or F1 ATI blower would work very well
wow i cant wait for the innercooler so I can run 22 psi..lol
http://www.ls1motorsports.com/Project-Camaro.asp
Even though Rob's single turbo was super-bad and very well sorted, he still 'only' dyno'd 707rwhp and went 136mph in the 1/4.
Don't get me wrong, I am far from putting down that beast, but if I'm right you want performance that is a notch above that, right?
If you are 10.7:1 now with 5.7 heads, I am guessing they are milled .050 - .060.
So you are at like a 62cc chamber. A 6.0 head is ~70cc stock so 9.5:1 is attainable with more bowl work.
I'd also go to a 3.55 gear if you like to run from a roll.
I'm guessing your 397ci would be a big bore motor, I bet it would be hard to hook and believe me you don't want more low end if you race on radials.
I'd like to see more folks build 346ci - 348ci FI motors I think we can do a lot with these motors, the mod 4.6 stangers are running 8's and 9's and they also have a 3.900 bore.
