which gauges are necessary when procharging
Old Jan 12, 2008 | 03:01 PM
sscamaroburn02's Avatar
Default which gauges are necessary when procharging
Okay next month I'm procharging my car. I was wondering which gauges are necessary besides a boost gauge. I really only want to get a dual pod setup as I really don't like the 3 gauge look. If you have pics of your setup let me see them so I can get an idea.
Thanks
Old Jan 12, 2008 | 03:11 PM
dixonk's Avatar
You should get a fuel pressure gauge as well. And a really nice gauge to have is a wideband.
Old Jan 12, 2008 | 03:13 PM
Websy21's Avatar
I agree with the abov, atleast those 3 minimum and if its an auto than add a trans temp gauge to the mix, especially if its a 4l60-e. I see in your sig its an M6 though.
Old Jan 12, 2008 | 03:41 PM
on the fuel pressure gauge. i noticed some go to 15 psi and some go to 100 psi. Which one do I need? Sorry this stuff is all new to me.
Old Jan 12, 2008 | 04:12 PM
lionelc-5's Avatar
I assume your using 60# injectors, so you need the 100#
Old Jan 12, 2008 | 04:15 PM
ChevyChad's Avatar
8 sec potential, 12 sec slip
low pressure is for carbureted engines. Fuel injection requires the 100psi gauge. Base fuel pressure for an LS1 is 58psi. So get the 100psi gauge. I agree with the statements above- you need boost, fuel pressure, and wideband.
Old Jan 12, 2008 | 05:05 PM
calongo_SS's Avatar
If you're only going to get two, get a boost and a wideband. I'm not running a fuel pressure gauge, I rely on the wide band to tell me if it is leaning out.
Old Jan 12, 2008 | 05:23 PM
dixonk's Avatar
The fuel pressure is cheaper than a wideband though.
Old Jan 12, 2008 | 08:53 PM
EPP's Avatar
EPP
I feel that for two gauges a fuel pressure and a boost gauge are the two to go with.
Fuel pressure at idle should be approx 58-60 psi, at wide open throttle it will drop down to approx 54 psi on a stock style fuel pressure with an adequate fuel pump. With knowing this info and with what you normally see with your system, if the pressure changes then you'll know you have a problem.
A boost gauge will allow you to make sure you're still seeing the same amount of boost that you did on that first boosted day, as once you get use to the extra power, you're start wondering if the belt is slipping. lol Bob
Old Jan 12, 2008 | 11:35 PM
Urban Legend's Avatar
TECH Cry Baby BOSS APPROVED!
Originally Posted by Exotic Performance Plus
Once you get used to the extra power, you're start wondering if the belt is slipping. lol Bob
LOL.
Old Jan 13, 2008 | 11:52 AM
ok thanks everybody. I think I will go with boost and fuel pressure for now. maybe add a wideband somewhere else besides the pillar.
Old Jan 13, 2008 | 05:23 PM
Websy21's Avatar
Many install them in a air vent I'd rather get a triple pod myself though but I think I'll being doing both and running 4 gauges minimum
Old Jan 13, 2008 | 07:38 PM
yeah i've seen a few installed in the vents. that looks pretty cool. i just think the triple pod is too many. just my opinion
Old Jan 13, 2008 | 09:12 PM
Schantin's Avatar
My personal $0.02 is a wideband AFR and fuel pressure. If I only ran one gauge, it would definetly be AFR. No other gauge says "Hey stupid, get off the f$%^'n gas or you'll blow your engine!!" like the wideband AFR gauge.
I have AFR, fuel pressure and boost....and to be honest, I rarely ever check the boost gauge.
Old Jan 15, 2008 | 09:35 PM
you do have a point there. i still have time to think about it
Old Jan 15, 2008 | 09:52 PM
ChevyChad's Avatar
If you must only have 2, I'd say boost and wideband. But you really do need all 3 minimum...
Old Jan 15, 2008 | 10:17 PM
DuronClocker's Avatar
I've got the same problem. I had a 3-pod pillar and didn't like how it looked, so I sold it and bought a 2-pod pillar. The third gauge on the 3-pod pillars is positioned fairly awkwardly.
Anyways, I'll be running all of three of the above-mentioned gauges, and I'm trying to decide where the third gauge is going to go, and which gauge it will be. I know one of the sponsors carries some nice little rectangular displays for AFR, but I was really thinking I'd like to have AFR on the pillar so I could see it more easily. Still something I'm trying to figure out.
Old Jan 16, 2008 | 08:07 PM
Schantin's Avatar
You have a couple choices for gauge placement. One is on the steering column (see my sig pic). Another I did on my friend Ricky's ProCharged car is to slot an Autometer trim ring and place it in the vent above the headlight switch. Looks great there and only takes a couple hours to mod. I don't have pics of that one, but he does (screen name RickyZ28)
