#7 Lean, Solution to re-route rear vacuum source
I'm currently getting a minor pop at RPMS between 2,000 and 2,500 under a load generally in third or fourth gear. When the pop occurs it shows a lean spike on the #1 bank O2 reading on the HP Tuners software for a split second and then it normalizes. My tuner is perplexed as it only occurs under this condition and the car and tune runs perfectly otherwise, boost at 8lbs AFR around 11.6 and 14 degrees timing.
A buddy of mine and I were thinking that I should re-direct my primary boost vacuum source up to the front of the manifold and perhaps even redirect my brake booster vacuum line as well upfront and on the opposite side. I'm going to try this to experiment but was curious if anyone else has tried or encountered this.
is this lean condition verified with a wide band or a stock narrow band sensor? It sounds like a tuning issue to me. Is the car running a MAF or SD?
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
I believe the common #7 failures are the result of a cooling issue as well.
At WOT under boost the air to the vacuum booster or map sensor is stagnent and will not affect anything with the tune.
Kurt's intake manifold experiment proves this to be the only answer.
Under full power #7 must get hotter than the other cylinders which leads to detonation and eventual meltdown of that cylinder.
A safe tune and forged pistons will give you a much larger margin of safety.
This is part of the reason for going to E85 for my build, much safer power.
Tiago was nice enough to shoot me one of his race gas tunes for a
starting point.
I will basicially bump the fuel pressure until the low speed is happy for initail break in
then start street tuning easing into boost a little at a time.
If there is a problem with the tune at that load and RPM it will not show up on the dyno because the engine is not operating under the same conditions.
Maybe throw a little fuel at that part of the MAP and see if it fixes the problem.
Otherwise, check for bad grounds, sparkplugs, etc...
Good luck!
John D, this occurrence happens right at the entry point of boost or just before with the throttle at 30% or less. Any more throttle including WOT and it does not do it.
engineermike, what could be causing my mis-fire as I agree it could be one i just installed new NGK TR6 splugs gapped at .028 and new GM Packard wires.
camarols1, I'm running a 6 speed tranny and it has done it in 2nd, 3rd and 4th gears under a load (going up a hill) at part-throttle and low RPMs. we played around with richer and leaner AFR's and it nothing we did tune wise affected it, like I said the AFR's remain constant it just the driver's side O2 that shows the instant spike
I'll try my vacuum theory and go out for more testing and report back later today.
Thanks guys!!
It's more likely that the MAF is a cause of your problems though.
I noticed I was getting some oil spillage from my breather that covers my oil fill hole so I decided to take the plug out of the valley cover and run a 12 inch piece of 3/8" fuel line connecting a separate breather, hopefully this will prevent some of the excessive oil that was coming through the oil filler breather. How is the ventilation system suppose to work. I have a hose/breather at the back of the driver's side valve cover and the passenger side valve covers plugged along with the throttle body vacuum port plugged. Assuming I had a vacuum leak that is now cured, what will this do to my AFR because I just had it tuned the other day. Will it now be leaner or richer or about the same. It was set between 10.5-11.5 depending on the load and gear. I would think a vacuum leak would cause it to run lean and now it may be a tad bit richer which is safer anyway right?
The solution is an oil catch can before the PCV inlet, and frequent emptying out of the oil can (it overflows when it's full). Most of the pics showing a dead #7 also show an oily path into #7 which is usually considered as part of the damage instead of the cause.
