Which AFR heads for 4.010 bore?
Old Jan 21, 2008 | 08:17 PM
Jay Johnson's Avatar
Default Which AFR heads for 4.010 bore?
Will the AFR 225(2.08/1.60valves 72cc chamber) heads have a problem sitting on
4.005 bores?
I want to run these with a single T-88, but I don't know if I have to go down to the
AFR 205's since I'm not running a 4.100+ bore.
Block is an LS2.
Jay Johnson
Old Jan 22, 2008 | 09:27 AM
ChevyChad's Avatar
8 sec potential, 12 sec slip
I would think you'd be ok. There are people running the big bore heads on 3.9 bore blocks. I'm one of them
Old Jan 22, 2008 | 09:40 AM
speedracer5532's Avatar
4.005 bores?
Block is an LS2.
Jay Johnson
The 225s will work perfect on your setup.
Old Jan 22, 2008 | 03:32 PM
SuperZ's Avatar
225s fo sho
Old Jan 23, 2008 | 04:34 AM
EPP's Avatar
EPP
Give me a call for a great price on AFR heads if you need to buy them. Bob
Old Jan 23, 2008 | 08:27 AM
No Juice's Avatar
I was wondering about this same thing.
What are the advantages of running the 225 vs the 205 on boosted 347?
Old Jan 23, 2008 | 08:37 AM
kp's Avatar
kp
I used the 'small bore' AFR 225s on my 347 Jay, I think they would have worked fine on the new 4.005 engine I just put in too but I went with a new set of 72cc 225s instead. I've seen guys run the small bore heads on 4.005 bore engines and I've seen guys use the 72cc ones on 3.905 bore engines and they all seem to work fine..
Old Jan 23, 2008 | 10:29 AM
Bob@EPP, send em a pm with a quote. Calling didn't work for me.
Jay Johnson
Old Jan 24, 2008 | 05:07 AM
EPP's Avatar
EPP
Thumbs up
Jay Johnson
Thanks for being persistant and calling me, Jay. Our phone lines get real busy during the day and I don't always have time to get on here during the day to check my pm's. Bob
