What Comp Lobe are you using on your FI and why?
Also tell why you chose that lobe?
Any gains going from XE to XER or other?
Jim
Go check out the .50 thou, .006 thou and advertised duration of the guys running 8's on a hydrauilc roller and you'll see the point.
The more aggressive the lobe the harder it is for that wheel to stay in perfect contact with that lobe.
Next point is the springs-the typical dual spring is rated at 130-140lbs on the seat. that's fine for N/A but stuff 20lbs off boost in the cylinder and then ask that spring to stay seated-it's alot harder. So we can shim the spring to build more seat pressure-to a point. Most of the duals are only rated for .650 lift so how much extra seat pressure can you get if your cam is already over .615 lift-with a XER lobe?
An XE lobe which has easier on, off ramps all are under .600 lift so we can still shim the spring up for big boost. But not too much as you'll over power the lifter.
Bro-your cam for example is on the XE lobes-I bet you wouldn't make a drop more power if you went to XER lobes-but what you would pick up is a noiser valvetrain and shorter spring life-so if the more agrressive lobe doesn't offer greater power gains, but requires you to change springs more often and listen to that sewing machine what would you choose?
When I test the LS6 versus the VicJr I hope to buzz the the motor past 7000, the cam(S) i have picked are both non-aggressive lobes so I can get extra pressure on the springs so they don't float and the power goes flat. I've got some trick pushrods and rocker arms I'll be using as well-and best part is none of this stuff will break the bank. I'm not just looking for big peak numbers but a nice fat curve that doesn't fall off a cliff after peak.
Of course when i'm all done i'll give you guys exact specs and part #'s as always!
I'm running Crane 99893 springs, which when shimmed to 160 lb seat, gives me a tad under 400 lb open and don't bind until almost .700". I could run up to .650" lift on these and still be ok from both spring pressure (420 lb) and coil bind (.050 margin) perspectives.
Mike
The effect of boost psi at full valve lift is much lower than the max of 62. If you have good cylinder filling it is almost zero because the cylinder is at almost the same pressure.
So you need to spec your springs to plan for that, and it's the seat pressure & and very low lift spring rating that most affects that part of the cycle.
IMO, the exhaust spring is almost unaffected by boost except for possibly taking a turbo setup's extreme backpressure into account during the very last part of the exhaust closing cycle. It wouldn't affect a SC setup.
Jim
With Vette all i'm trying to do is keep the power soft on launch but come on strong ontop-so if I can make the same power/torque as the 347 up to 3500 I should be good. I know it's not great but it was getting 1.47 sixty's leaving off idle with the 347.
With the same cam as the 347 in the 402, it blew the tires off on the dyno at 4500 rpm with no timing in the car-hopefully the new cam will shift the power curve over abit!
