Main girdle
Old Jan 24, 2008 | 03:39 PM
427's Avatar
427
The tune was the same on Steve's car when he went 189. I don't think you could see over 1700hp on the head gaskets with an aluminum block, but more bolts will help! The law of diminishing returns will start to apply, but if Mike and Steve can get near 2000hp they will go near 200 if the tires let them. I expect to see the "Red Rocket" in the "200" range when you guys get more time on it.
The thrust bearing damage is likely related to his staging, but with over 200 runs I would call it acceptable. We will still be looking for ways to make it last longer though! One thing that will help is recording your thrust endplay before you take the car out to see if we can "map" how long they last.
Kurt
Originally Posted by y2khawk
if they had actually put some boost to it on the dyno it would have pegged it like paul did. Steve was running in the mid 180's at 3400, it's probably a little higher than 1600.
I'm betting his thrust bearing is more a result of the forced staging habits we have for turbo cars. I'd be curious to see what Tom's looks like after the burndown.
Old Jan 24, 2008 | 03:43 PM
sr71bbjr's Avatar
Kurt
Please explain what that means.
Old Jan 24, 2008 | 04:05 PM
Inspector12's Avatar
TT-TECH Veteran
It seems like he is saying to take before and after measurements to see what the change is . I don't think you would want to wear past point X before replacing the bearing is all he is saying I believe. I am running the girdle on both of my cars and will say that I probably would opt for billets and pining the crank IMO. After using them I don't think they are doing much exept for main cap strength itself. I haven't had any main issues caused by the girdle yet I just think that the other pinning the mains is a safer and just as strong.
Jeff
Old Jan 24, 2008 | 04:32 PM
427's Avatar
427
12 said it perfect! If Turley, Brown, Harlan and Kempf all start gaining endplay at 100 passes, you know to change the bearing at 90 passes. If you gain .001 every 5 passes, then a fix will need to be made. Until you have some time to collect info, we can only use our best guess.
We can do things that will protect the thrust, but is it worth the cost of change is the question.
Kurt
Old Jan 24, 2008 | 04:45 PM
TwnTrboCE's Avatar
Like Kurt said...Once it goes out of range we'll know after so many passes it's time to throw in a new one. We usually just run them all season then crack them open and see what was and wasn't happy.
Inspector12, it would be interesting to see how much the caps have been walking on your motors with that girdle. The pinning makes a huge difference.
I ran stock caps on my old stock LS2. The caps were sawing bad on the motor. But it went 8.50's @ 3700lbs. I think pinned stock caps will hold a lot of power. A buddy of ours is going to be running that this season in the 1200 range. We'll see what happens...
Also, the girdle we run on the Camaro is the W2W one. Not the thin one in the pictures.
Old Jan 24, 2008 | 05:35 PM
01ramair500hp's Avatar
Originally Posted by 88GT&69ss
if you have the cash ...LSX block !
i already have the shortblock. iron 6.0, compstar crank, howards steel rods, diamond custom piston. will have shortblock back next week. Pro line racing in Atl bored and assembled for me.
Old Jan 24, 2008 | 07:51 PM
ABeasst's Avatar
can someone explain pinning the main caps?
Old Jan 25, 2008 | 02:19 AM
TT-TECH Veteran
It is a solid dowel that is drilled into the block and the main cap to make sure as the block tries to move the pins will help keep the motor more stable and stronger.
Yeah I am not that pleased with that part of my motors as I asked about pining the caps also and I was kinda pushed away from that by the builder, I think by the extra work involved, but I know they are moving a little as I just put the black car back together and you could see a little bit of movement on them not bad, but it doesn't have a ton of miles on it either. That is to be expected though anybody making @ 600rwhp on an aluminum block will show some movement from what I have seen and that is just a given.
Old Jan 25, 2008 | 06:51 AM
y2khawk's Avatar
my pinned block from 2002
Old Jan 25, 2008 | 07:17 AM
ABeasst's Avatar
how big are those dowels and how deep are the caps and block drilled?
Old Jan 25, 2008 | 10:14 AM
xLBx's Avatar
LSX is a heavy weight ... I would go Warhawk just to save the weight. The world block is an easy 100-150 lb off the front of the car compared to the GM Iron block.
Old Jan 30, 2008 | 12:22 PM
  #32
revlimiter's Avatar
These guys plan on running in the LSX shootout, and no aftermarket blocks
Old Jan 30, 2008 | 01:37 PM
  #33
NA$TY-TA's Avatar
Mike or Kurt,
would billit caps help over stock pinned caps??
Old Jan 30, 2008 | 05:32 PM
  #34
TT-TECH Veteran
Originally Posted by NA$TY-TA
Mike or Kurt,
I think the whole goal is to limit how much the block twists etc... I don't think it is a main cap strength issue. So I am saying that the billet caps might be stonger, but they won't do anything for the twisting unless they are pinned also.
Jeff
Old Jan 30, 2008 | 05:38 PM
  #35
Shawn @ VA Speed's Avatar
pinning the caps is to prevent them from walking,unpinned caps will move around alot on high hp applications-all aftermarket blocks have pinned or doweled caps,billet caps will do it less because thet dont flex as much but they still will walk
Old Jan 30, 2008 | 06:42 PM
  #36
TwnTrboCE's Avatar
Mike or Kurt,
I agree with the above... I would run pinned stock caps over unpinned billet.
Old Jan 30, 2008 | 07:55 PM
  #37
ABeasst's Avatar
anyone have pictures of pinned main caps?
Old Jan 30, 2008 | 09:55 PM
  #38
Mr.MartyStone's Avatar
Post 29 of this thread...scroll up
Old Jan 30, 2008 | 10:13 PM
  #39
ABeasst's Avatar
dohh....thats I missed that
Old Jan 30, 2008 | 11:13 PM
  #40
Websy21's Avatar
This is out of my league but nonetheless some good info here. Might I add if I was rich it would be twin hairdryers on a LSX block and best heads money could buy time right about now
