My build - Lots of pics
Old Mar 14, 2011 | 08:49 PM
  #341
Sideways240sx's Avatar
The manifold is from mcmastercarr.
Thanks chris
Old Mar 18, 2011 | 09:37 PM
  #342
http://www.youtube.com/watch?v=q8xOQpEMzWQ
Old Mar 18, 2011 | 11:09 PM
  #343
radioflyer86's Avatar
that thing sounds like a WWII Warbird! Awesome!
Old Mar 19, 2011 | 10:25 AM
  #344
s25hanh's Avatar
amazing build. subscribing
Old Mar 19, 2011 | 07:15 PM
  #345
Thanks guys!
Old Mar 19, 2011 | 10:50 PM
  #346
armintheman's Avatar
love the build bro! quick question...how did you paint the intercooler? what kind of paint was used?
Old Mar 20, 2011 | 12:39 AM
  #347
Eastwood radiator paint. Check out eastwoods site if you never have, they have some pretty cool stuff!
Thanks chris
Old Apr 3, 2011 | 02:04 PM
  #348
Broke EF's Avatar
So this weekend the main goal was to get the car down to Eric at Midwest Chassis to get the chute mount and window net installed. So Friday night we loaded up the car and got everything ready, we needed to be up EARLY Saturday. Here is a shot of the proud owner (Chris) with his baby.
He looks so happy
Saturday morning we go up at 5:30 and hit the road about 6AM. Here is a shot of the car on the way down as the sun came up.
We got to Eric's about 8:30 in the morning and unloaded the car. I'm sure his neighbors liked the TA alarm clock Eric got to work on the window net first, and we went to go get some breakfast. Here are some quick pics of what he had when we got back.
Shot of the top side of rear bar. This is the only one that is permanently attached to the car. This makes it nice if you want to pull the net out, there is nothing in the way.
Close up of the weld
Here is the lower side of the same bar. You can remove the bolt, and move the bar out enough to slide the net off.
This is the lower part of the front bar. This is on a heim joint to allow plenty of movement so the net can get out of the way for getting in and out. This bolts to a threaded insert on the cage so you can remove the whole bar.
Same part from the inside
Here is the seatbelt clip that locks the net into place.
And the final product! You can see how the front bar bends out to give you a lot more arm room, a nice touch.
Next up was the chute mount. Eric started by bending up a piece of molly tubing, and tacking it to some molly plates the Jason made earlier.
You can also see that he had already marked the tube for the piece that comes through the bumper.
Here you can see Eric welding up the piece that slides into the receiver on the car, and holds the chute cable.
And here is that same piece all welded up, and drilled for the pin.
Eric is bolting the fully welded cross bar onto the car so that he can check the alignment of the receiver in the center be fully welds it in.
Got it perfect, and welded it fully along with adding a couple gussets for strength.
Here is the whole thing minus the chute holder.
Somewhere in that whole deal Eric whipped up the ring that holds the chute and the launcher. Here is a pic of the weld on one of the 4 tabs that the launcher will bolt to.
While the mount was cooling off he did us a favor and welded in a sleeve for the passenger seat back bolt to go through. You can see him working the TIG pedal between his legs to get this done!
He also added piece to hold the shoulder belts in place. I didn't get a pic of him doing that, but it didn't look easy
Once that was all finished he got back on the chute mount. He started with the two lower pieces to hold the ring in place.
Then after measuring, checking, measuring, and checking a few dozen times he made up the top two pieces. These have threaded inserts in the end of them (on the car side) so that the whole thing can be removed. The he added the two braces on the sides for extra strength
We planned on getting some more small things done to the car Sunday, but it didn't work out. The only big project left is swapping out the ECU so that we can crank up the boost. Then we have some dyno tuning, chassis cert, and finally RACING!!! We will keep you all up dated, and thanks for following along!
Sean
Old Apr 4, 2011 | 08:02 AM
  #349
vipermike2002's Avatar
Holy RACE CAR.
Chris, I have a extra set of GM grill covers for a WS6 hood, do you want them?
Old Apr 4, 2011 | 08:19 AM
  #350
Originally Posted by vipermike2002
Holy RACE CAR.
Thanks
The vfn hood came with some aluminum ones that i had powdered black
They just are not on the hood yet. Thanks for the offer though!
Chris
Old Apr 4, 2011 | 11:42 AM
  #351
willizm's Avatar
very nice purpose built machine you got there.
Old Apr 4, 2011 | 12:00 PM
  #352
Thank you!
Chris
Old Apr 4, 2011 | 12:35 PM
  #353
ablakez28's Avatar
Looking good.
Old Apr 4, 2011 | 12:43 PM
  #354
TracyRR's Avatar
Very impressive!!
Old Apr 4, 2011 | 12:46 PM
  #355
Thanks guys!
Chris
Old Apr 4, 2011 | 02:53 PM
  #356
jdhedman's Avatar
**** yes Man Sick build.. Hope I get a chance to see it in action this season
Old Apr 4, 2011 | 03:06 PM
  #357
Thanks. If any of the local guys see us out @ the track dont hesitate to come up to us.
Thanks, Chris
Old Apr 4, 2011 | 04:05 PM
  #358
jdhedman's Avatar
I am sure you will be seeing me and a bunch of my buddies/local forum guys out there. That is just nasty and beautiful LOL makes my build look like a child's toy thing
Old Apr 4, 2011 | 04:17 PM
  #359
norotor7's Avatar
Looks great. Eric does good work.
Old Apr 4, 2011 | 04:31 PM
  #360
Broke EF's Avatar
Thanks for all of the kind words guys, it means a lot to Chris and I. Eric does fantastic work, and thats why we use him for everything. The car has already proven his parts work, but it will really show it this year!
Like Chris said, if you see us out come by say Hi, and check out the car. It always cool to meet people who have been followin along with the build. We should be at most of the local tracks this year. Byron, Great Lakes, and Cordova for sure, maybe Route 66, and 41 too.
Sean
