My build - Lots of pics
We starter off @ 3500 with 5 degrees of timing, and it bogged. Went to 4,000 with 5 degrees, still bogged a lil. Went to 4,300 with 8 degrees, and pretty much no bog.
Chris
Whatever happened with your car? I hope you decided to keep it after all the time and work you have into it.
Sean
More or less what Broke ef said. Jerry @ SP did the maf tune. @ the time he thought it would be best. @ first the car ran very good. Pulled awsome on the street, had good mph, first time at the track, but no tires.
2nd time @ track, mph fell a little, but way better et cause it was on a tire. 60 ft wasn't where we wanted so we added a 2 step.
3rd time with the 2 step, car was doing good in the 60 but fell on its face on the top end. I think it might of been part from oil in the intake, maybe going lean a little cause of gear change, maybe bad knock sensors?? lots of variables.
Speed inc was always an option to get tuned, but Chris and Jerry over @ Sp were very good to me with advice during the build, and with random parts i needed so i threw them the business.
The car will run better next yr, and most importantly i will be able to data log it with Hp tuners.
Chris
glad to see you are getting it ironed out. HPT or any tuning/logging software is a must IMHO. I can't drive my car around the block with out logging it and making adjustmentsJ
Chris
Sean
My car is dirty
Looks good Chris, I still need a ride someday. Got any other pics?
As far as tuning, your own tuner is great! I have one for the GTP. Its nice to change anything anytime you want. If speed INC leaves the pcm unlocked maybe have them tune the car, (Get a very good place to start from) then make edits with HP tuners anytime you need.
Two years ago Sean and myself bult a truck manifold turbo kit. Turbo kit uses a Precision GT42-76, Tial 44 gate, and Tial 50mm Bov.
The car used a walbro 255 pump, 60lb injectors, a ls6 intake, and mafe tune(didn't work out so great) 460ish whp @ 6psi...
Current build is getting
Brand new Lq9 block(370)
Stock Crank
Callies Rods
Wiesco Piston
Arp Main studs
Arp Head Studs
Patroit Stage 3 317 heads, Patriot Gold springs
Fabd valve covers with -10 bungs for a catch can
Custom Spec'd Turbo Cam
Ls7 Lifters
Brand new Gm rockers, with comp cams Trunion Upgrade
ls6 Intake
Stock Ported TB
Speed Inc Fuel rails
Fuel Lab regulator
Fuel Lab filter
-8 feed
-6 return
2 Walbro 255 pumps in take, With racetronix hotwire
The same Truck Manifold Turbo kit is going back on.(for now)
Suspension is All midwest Chassis Everywhere.
Rear Lower control arms, and panhard bar
Fron Upper, and lower control arm, Spindle, Manual rack, K Member
Rear stock spring, with Comp Engingeering strut
Front Stage Drag coilover
Brakes
Midwest chassis Manual Master
Replume the entire Car with brake line, and Strange 4 piston drag brakes @ all 4 corners
Trans
Drc Th400 with transbrake
B&M ratchet Carbon Fiber shifter
Tci Trans cooler
PTC Specd Turbo Converter
Rear End
Midwest Chassis Fab 9
spool, 35 spline axles, ect
Motor should be in this week, and the rest of the parts i pretty much have. Just need time to get them all ont he car, and get everything else done at the same time. Weight of this car should come in right around 3000 lbs, without a driver.(I think) I am hopeing in 6-8 weeks to have the car running, and begin the tunning again. this time it will be a 2 bar SD tune.
Futur plans consit of Upgrade to a 99+ ecu, so i can run 3 bar SD, with bigger injectors, and Get a bigger turbo, and Redo the turbo kit!
We started this weekend by mostly pulling out some weight, and generally got the car ready to carpet. I don't really have any pictures of specific work on this, but basically sean chopped out un-needed brackets, pulled excess wiring, and anything not needed. I got to work pulling the crash bars from the doors, changing the rear brakes, swapping out the rear control arms, and panhard bar to Midwest Chassis pieces. On with the pics.
This is somewhat before work started
Front view (had already pulled the e-brake and center brackets in this pic) You can also see the stock wheel is gone, and the quick release installed.
From the other side
Here is a shot of the stock brakes
A couple of comparison shots between the stock rotor and the strange rotor
And the strange brakes done
Started on the shifter mount/filling the 6-speed shifter hole
Tacked in
didn't get it finished, but its closeish here
whipped up a panel to cover the access hole in the back, you can also see we installed the HVAC delete panel
Here is the pile of **** we pulled from the car
And here is the weight of the pile
Well thats all for this week, it doesn't look like much but it was a lot of tedious work done. Thanks for looking!
Do you have any pic's posted on here of the pipe coming from the turbo and how you tied it back in with the exhaust. Or did you just dump it under the car? Thanks Kris
Started out by turning the car around so we can get to the front easier.
Quick shot under the hood before work started
Having the right tools was key this weekend! This was removing the pedal assembly and the long extension made it a million times easier.
After pulling the brake master cylinder, and the booster. Also the clutch master cylinder is out too.
Up in the air to pull the fuel and brake lines
Here is the pile of **** that got yanked out this weekend and trashed. The top pile is stuff that is going to be modified and put back in.
No more wiper motor/arms. The stock plastic cowl cover is going to go back on.
This picture turned out bad, but this was after everything was pulled out.
Well that is all for this weekend, like I said not too exciting to look at. Now that the last of the tear down stuff is done we can start with the fun part, putting it all back together! Lots of parts came in this week, and the last of them will be here in the next couple of days. Next week should start the more exciting post where it actually looks like we got something done.
Thanks for looking!
Sean
