sts turbo tailpipe problem
Old Feb 1, 2008 | 04:24 AM
sowaidi's Avatar
Default sts turbo tailpipe problem
after 3 months without a muffler or a tailpipe on my STS kit, i put one there today and i hate it because the truck wont make full boost and would only make it at higher RPMs. i didnt put a muffler, it is a 3 inch tailpipe that goes on the right corner. what are you guys with turbos using as a tailpipe or what would you recommend?
mods are:4.8 5 speed, Sts Turbo @7psi, Pacesetter Lts, 220/220 cam
Old Feb 1, 2008 | 07:32 AM
NYSS Guy's Avatar
That's weird. I have a Borla XR-1 after the turbo, and the car makes full boost by 3600-ish rpms (and that's a T76). Granted I'm only boosting 5 psi right now. I didn't see much of a difference in spool time at all when I put it on. I'm sure this doesn't help much, but just wanted to let you know my experience.
Old Feb 1, 2008 | 07:51 AM
lionelc-5's Avatar
Why do you have headers with the STS?
Old Feb 1, 2008 | 11:50 AM
deadmanTA's Avatar
Put the stock manifolds back on and wrap the hotside all the way back to the turbo then use a bigger diameter tailpipe. That should drop the spool time down.
Old Feb 1, 2008 | 12:00 PM
sowaidi's Avatar
i had the headers on before the sts setup. ill try my best
Old Feb 1, 2008 | 12:04 PM
GTObsessor's Avatar
Loose the headers and wrap the stock exhaust all the way from the manifolds to the turbo.
Old Feb 1, 2008 | 12:15 PM
NYSS Guy's Avatar
The headers aren't helping, but if it was making boost before the tailpipe, and all that was changed was adding the tailpipe....something's got to be up.
Old Feb 1, 2008 | 01:07 PM
Blackbird's Avatar
the million dollar question, take the tailpipe back off, does it go back to normal?
it might be something else completely but a freak coinkydink that when you put the tailpipe on it cropped up.
Old Feb 1, 2008 | 01:18 PM
sowaidi's Avatar
thanx for the help
Old Feb 1, 2008 | 02:43 PM
TNTramair's Avatar
+1..
Old Feb 1, 2008 | 07:49 PM
2002ws-6's Avatar
It may all be in your head too. I did the same thing, with the car quieter it just doesn't sound as fast. I also felt like I had a lot more low end torque with the muffler after the turbo than without.
Old Feb 1, 2008 | 08:36 PM
ZL1Killa's Avatar
i have the stock exhaust pipe and i build boost fine. wrap your exhaust from your y-pipe all the way back to the turbo.. yoiu will cut down spool time (spool quicker)
this is before i wrapped it
Old Feb 1, 2008 | 10:54 PM
Schantin's Avatar
Try iy w/out the tailpipe and see if it makes full boost again. If yes, use a BIGGER tailpipe, like a 3.5" diameter. There was a previous thread concerning tailpipe diameter, which should be 1.5x the turbo outlet diameter.
Good luck
Old Feb 2, 2008 | 12:32 AM
sowaidi's Avatar
thanx for the help guys
ill get a bigger pipe, maybe a 4 inch or the biggest i could get, and wrap the whole thing from headers and on
