Almost 700 rwhp with 10.5 psi APS TT kit
Old 02-09-2008 | 05:58 PM
TWS's Avatar
TWS
Good luck tonight J-M. Looking forward to seeing the timeslip.
Keep her straight and shiny side up.
Old 02-09-2008 | 06:29 PM
transamfreak01's Avatar
nice set up and make sure you let us know how she runs tonight
Old 02-09-2008 | 08:32 PM
MY99TAWS6's Avatar
Off the subject a bit but they have a couple of 1000hp twin turbo mag reviews linked on the afr website.I am pretty sure one of the builds used an carb type intake initially and then they put on a fast 90 intake and gained more power. But of course whatever a guy prefers.I had the fast already and aps used the fast 90 as did these two articles with no problems hitting 1000engine hp thru the fast intakes. And the fast fits perfect under stock hoods.
Old 02-09-2008 | 09:32 PM
Tiago's Avatar
looking good !
should run very well
Old 02-09-2008 | 09:41 PM
Derek @ EDO's Avatar
Nice! How do you like them DMH cutouts? Thanks again for your order!
BTW, car looks and sounds GREAT!
Sounds like a damn dragster with the cutouts open
Old 02-09-2008 | 10:18 PM
Inspector12's Avatar
TT-TECH Veteran
I know a lot of Speed Inc.'s cars have hit over 1K with an LS6 so i will assume that the fast wouldn't stop you from making that amount of power.
Jeff
Old 02-09-2008 | 10:30 PM
TNTramair's Avatar
Badass JM!!! very nice numbers indeed.
im very close with mine...everything is installed. just a few adjustments and finish up the exhaust than its break in time!!
Old 02-09-2008 | 11:03 PM
52172's Avatar
That looks excellent for a 480le. So you have a 402.Now what do you have for heads, exact cam specs ,intake manifold and tb,compression ratio. What was your afr and timing?
Where is the torque lines? Why did the one run end at 6200 and the other one at 6500?
Did you notice any sucking closed yet of the rubber intake pipes?
Sorry for all the questions but inquiring minds want to know. Oh and was this on just pump 92 or what octane?
If you were just on pump then with your alc hooked up would expect to see quite a bit of improvement as you can crank in more timing,lean it out possibly some more and of course dial up the boost. I really want to see those torque lines. I find torque really comes up with additional timing.
But don't get me wrong your numbers are already impressing me. Will of course be anxiously waiting for some driving impressions especially how the turbos pull as you go from about 6000 to 6500. The one line looks real good though not much drop off up there at all .After all we have a lot of naysayers on this forum about how the aps turbos are way too small for your 402 or my planned 408.But on the street a bit small is better than a bit big. And if you can hit 10s with "too small" turbos or a 9 then really what does it matter. Most factory cars have smaller turbos than optimal since smaller turbos spool up quicker and widen the powerband where its most useful on the street.
So assume you have some driving impressions or did you trailer it to the shop or thats where its been sitting while you worked on it?
Not much drop off at all because of the boost level of 10.5 once he tries to push it to 18 psi with race gas I am guessing a huge drop off above 5800 rpms. Jim when is turbo upgrade gonna become available?
Old 02-10-2008 | 12:42 AM
Lythropus's Avatar
I have a few questions.
Do you have a pic of the 28/12.50 tires mounted on your car? How's the traction with those tires on the street?
Old 02-10-2008 | 02:40 PM
RedLT4Mike's Avatar
I was out there @ SAR last night til about 1:30.
It was CROWDED and the track was slippery.
I was watching of course.
We were waiting to see your red wagon run!
Old 02-10-2008 | 02:45 PM
LSevil1's Avatar
+1, and bad *** car as well.
Old 02-10-2008 | 02:58 PM
  #32
slowredz's Avatar
What did it run?
Old 02-10-2008 | 07:22 PM
  #33
mongoose_ss's Avatar
any update?
Old 02-10-2008 | 07:36 PM
  #34
peter@aps's Avatar
Originally Posted by JMBLOWNWS6
Well today we got a late start on my car. Had a mustang on the dyno most of the day and we finally got a chance to put my car on there. I didnt have time to mess with the e boost so we decided to do some pull's as is. The car has been seeing 10 to 12 psi on the road (As much as you can watch a boost gauge and drive). But today on the dyno the intial spike was 12 psi then sayed right at 10 psi all the way up.
Very impressive power through the auto trans at just 10 PSI.
Peter
Old 02-10-2008 | 09:45 PM
  #35
VINCE's Avatar
Shorty Director
Very sweet setup!!
Old 02-10-2008 | 09:56 PM
  #36
Got Me SOM's Avatar
Shoulda def hit 9's.
Old 02-11-2008 | 09:00 AM
  #37
JMBLOWNWS6's Avatar
Oh also fighting to decide between nasty fuel system and aps fuel system. How loud is that 4303 really ? My car is pretty much pure street so trying to keep things as stock sounding as possible,within reason.
I driven this setup everywhere. No problems with the nasty setup. I dont like the evap delete. But I live with it. The pump isnt that bad. And has not turned off on me.
Originally Posted by xLBx
Very nice !
Thanks.
Originally Posted by NA$TY-TA
Bad *** man.... shes going to be a beast
So far it is way better to drive than my last setup. I wanted a LSX but it was too late and these twins wouldnt have been enuff. There's always next year I cant wait to see your's run Kyle!
Originally Posted by bad95killer
Very impressive man & get to the track ASAP
peace
Thanks! Should be this week.
Originally Posted by Inspector12
Congrats JM can't wait to hear times.
Thanks Jeff.
First of all I dont care about it fitting under the hood. Second I am using the stock PCM in 2 bar (3 bar very soon). So controlling each injector is not possible. And the air distrubution thru the vic jr seem's even. As # 7 seems to indicate. I choose the vic jr as alot of others have. Just like I choose trick flow's and not afr's. Its a free country. What works for me might not work for you.
Originally Posted by Tiago
looking good !
Im going to roll up to one of you guy's track events and try to have some fun
They are great! I really like them. Thanks alot Derek!
Once tuned its instant fun! I have about worn out my front brake pads boosting it up in 3rd on the highway
This is the exaxctly what I am expecting. Im thinking Im pretty happy with the numbers so far. Just need to turn it up a little bit more. Goal is single digit's and drive home with the ac and stereo going.
Traction is limited. I am spinning them pretty hard 1st thru 3rd. I will get a pic later. All the other pics I have suck.
Man Mike I tried. Dont worry very very soon now!
Originally Posted by VINCE
Very sweet setup!!
Thanks your car is sweet! Read about it a while back
If it doesnt Im building something else.
Peter.
Thanks Peter. Kits is doing well so far. Waiting for your high boost duct's
I wasnt able to go to the track. It was about 9:00pm and I went over everything in the car. Went to log the AFR and noticed it was going to 12.4 at WOT when I would stab it. Gently going into boost 11.6 So we knew the map wasnt perfect so I had my buddy Shawn take the car. He was gone almost 2hrs tweaking it. The car has one problem as of now that doesnt show up all the time. Under WOT we have the AFR parked at 11.5 Then the 5th run all the sudden the voltage drops to 11.35 and the AFR goes to 9.8. So the car kinda wants to fall on it's face up high. After we verfiyed some things it's the PCM controlling the voltage. So this is causing the injector pulse width to adjust itself based on battery voltage. I have a 235 amp alt, So we are going to upgrade my hot wires and grounds on the car and try to correct it or tune around it. This was the main reason I didnt run my car that night. Hopefully this week Ill be able to take it out and have some fun!
Old 02-11-2008 | 10:01 AM
  #38
Superman09's Avatar
LS1Tech Sponsor
jm, how is your pcv setup exactly, any issues with burning any oil whatsoever so far?
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old 02-11-2008 | 10:24 AM
  #39
JMBLOWNWS6's Avatar
I dont have a PCV system I just ran catch can's off each valve cover. Thats it I let my car run so the oil does get up to temp. Also I am a extreme oil changing type of person.
Old 02-11-2008 | 10:30 AM
  #40
xLBx's Avatar
Can't wait to see you pump up that boost !
I loved what you did with that novi z06, watch out fellas, this guy can DRIVE !
Quick Reply: Almost 700 rwhp with 10.5 psi APS TT kit
