turbo 5.3L or 6.0L?
single digit dreamer
parish used a ZO6 cam/springs and 50lb injectors
I can get a 6.0L for about $800 bucks... but I can get a 5.3L for a measly $400...
I'll prolly go with the same cam set-up, but I'm going to use 60lb injectors. Their 50pounders with at like 95% cycle duty!
so, here's the set-up so far: 6.0L with 60lb injectors, Z06 cam/springs, T70 turbo, 10.5lbs of boost, 93 octane.
should I go with a different set of rods? or will they be alright?
a 6.0 with cam at 9psi will make good power. on our 5.3 fairmont we ran a best of 10.4 on pump gas at less than 8psi.
Is it possible to bore the 5.3 to 6.0, or does the 5.3 have smaller outside bore diameter? Any other differencies? I can't get over that idea that I could have very cheap and easy 550 hp turboengine from the 5.3 at first and afterwards (or after piston damage) just bore it out and change pistons and rods and turn the boost up. Codeword: SmallBudget
![Embarassed](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_emb.gif)
Is it possible to bore the 5.3 to 6.0, or does the 5.3 have smaller outside bore diameter? Any other differencies? I can't get over that idea that I could have very cheap and easy 550 hp turboengine from the 5.3 at first and afterwards (or after piston damage) just bore it out and change pistons and rods and turn the boost up. Codeword: SmallBudget ![Embarassed](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_emb.gif)
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Yep, that iron 5.7L would be good compromise between costs and power. I've been watching off the shelf Mahle-pistons, I like their design and pricing. Does anybody have any negative about them?
