turbo 5.3L or 6.0L?
Old Feb 11, 2008 | 11:04 PM
melon07's Avatar
Default turbo 5.3L or 6.0L?
I have a masterpower T70. My goal is to make 600 to 650hp. I know I can get this out of a 5.3L, however I don't want to be pushing the limits. Do you think it is okay to get this out of 5.3? Or should I get a 6.0? Please post your thoughts on how I can get this horsepower number... thanks
Old Feb 12, 2008 | 11:42 AM
melon07's Avatar
If I can get 400hp out of just the motor, I should be able to pull around 600 with about 8lbs. of boost. If I hit 600 with either one, what would you do to make it more reliable? I heard the rods are only good for around 500, so I'm planing to change those... anyone have an opinion on which motor I should use?
Old Feb 12, 2008 | 12:04 PM
kbracing96's Avatar
Read this... 600rwhp out of a stock 5.3 with only a 01 Z06 cam and a MP T-70 turbo
http://www.1320video.com/gallery/HRMFairmont
Old Feb 12, 2008 | 12:14 PM
melon07's Avatar
yeah, thats parish. They got those numbers with race gas and like 12lbs of boost or something like that... I forgot to mention that I only want to run around 8lbs.
Old Feb 12, 2008 | 12:32 PM
melon07's Avatar
okay so I'm leaning more towards the 6.0
should I run a ZO6 cam/springs like most do with the 5.3?
Is their anything I need to do to a 6.0 for it to run 8lbs? or is everything pretty solid for that low of boost?
Old Feb 12, 2008 | 01:22 PM
Superado's Avatar
11 Second Truck Club
10+ lbs here on a 212,6xx mile 5.3L
ran 8 lbs from 70k miles up to about a year ago...
only upgrade required will be injectors and fuel pump...IMO...
Old Feb 12, 2008 | 02:47 PM
melon07's Avatar
superado, what are you putting out hp wise?
Old Feb 12, 2008 | 05:10 PM
Grr's Avatar
Grr
i run between 9-12psi on a completely stock 6.0, just a cam. Im making about 670hp(crank). All you need is the zo6 cam and a fuel system and it will take alot. I dont even run a intercooler, just pump gas. If you can get a 6.0 cheap enough its a no-brainer, but the 5.3 is just so cheap its hard not to go that route.
Gary
Old Feb 12, 2008 | 05:28 PM
RAGENZ28's Avatar
Article I read said he bought a used Ls6 cam for 60 bucks.
Old Feb 12, 2008 | 05:35 PM
woodys_customs's Avatar
I have a 5.3 I am currently building for a 1999 Camaro. I am going twins with LS6 cam and a good tune. I am shooting for 550HP!
Old Feb 12, 2008 | 06:30 PM
melon07's Avatar
parish used a ZO6 cam/springs and 50lb injectors
I can get a 6.0L for about $800 bucks... but I can get a 5.3L for a measly $400...
I'll prolly go with the same cam set-up, but I'm going to use 60lb injectors. Their 50pounders with at like 95% cycle duty!
so, here's the set-up so far: 6.0L with 60lb injectors, Z06 cam/springs, T70 turbo, 10.5lbs of boost, 93 octane.
should I go with a different set of rods? or will they be alright?
Old Feb 12, 2008 | 06:38 PM
Dragframe's Avatar
same thing?
Old Feb 12, 2008 | 07:44 PM
melon07's Avatar
yea they're the same... I was just listing his mods.....
anyway, will the rods be okay?
Old Feb 12, 2008 | 08:57 PM
Superado's Avatar
yes they should be ok...it's the piston(s) that will go IF anything...
there are guys running stock rods w/ forged pistons making damn good #'ers...
Old Feb 12, 2008 | 09:20 PM
kbracing96's Avatar
Ya, rods are plenty strong. I've seen 10 times more broken ringland from detention on stock boosted motors then broke rods. If my 4.8 can make 500+ at the wheels with 12 psi, pump gas and windshield washer fluid for meth, I think with 70 more cubes you should be able to get 600. Maybe not with 8 lbs, probable more like 10-12, but a stock motor and a Z06/LS6 cam with a good tune should hold it.
Old Feb 12, 2008 | 09:39 PM
GXPJAY's Avatar
Any more info on stock rods and aftermarket pistons?
Old Feb 13, 2008 | 07:09 AM
BigJls1's Avatar
front or rear mount.
Old Feb 13, 2008 | 10:39 PM
melon07's Avatar
are you asking me buddy?
front mount, a lot like this
Old Feb 14, 2008 | 12:15 AM
melon07's Avatar
what should I do for a fuel system? 6.0L, 60lb injectors, T70 turbo.....
can I use the stock '93 v-6 camaro tank with a 'in tank' fuel pump (larger one of course) or should I sump the tank and put an in line pump on? I have no clue how big of one I need, so some gph numbers would help too...
Old Feb 14, 2008 | 10:32 PM
BigJls1's Avatar
Yeah guess I forgot the ?. Cant really help just was curios on your setup.
At least I got you a bump this evening.
