Turbo or Supercharger
Old Jul 15, 2003 | 07:07 PM
Jackstand's Avatar
Default Turbo or Supercharger
I am looking into getting a turbo or a supercharger. What one should I get, and where can I find the info. I am looking at around 6k to spend. Oh yeah, is there anything else I should get to prep my engine, tranny, or rear.
Old Jul 15, 2003 | 07:23 PM
Crunch's Avatar
Default Re: Turbo or Supercharger
Oh no!!
Good luck!!
Old Jul 15, 2003 | 07:46 PM
Jackstand's Avatar
what do you mean OH NO!
Old Jul 15, 2003 | 08:33 PM
Warbird's Avatar
When you write the first check make sure you can write plenty more 8K is a fair starting point
slow's Avatar
you just opened the turbo/superhcarger debate.
a strong rear end is a good idea.
Auto or manual transmission?
Ryan.
Old Jul 15, 2003 | 08:59 PM
10.5 Dave's Avatar
7 Second Club
From: Grove City Ohio/Port Washington L.I sometimes
Jackstand I say double that 6k and you will be alot closer to what it will take.When you start making some power the stock tranny(A4)rear,clutch arent up to the task.Have some backup $$ for all the incidentals.
Old Jul 16, 2003 | 12:04 AM
gogogadgetcar's Avatar
are you a competent "do it yourself" kind of guy? if so you can save lots of money that way. If your goals are fairly low (less than say 450rw hp/tq)you can do it with 6K easy. You can find a used turbotech kit for less than 3K. Put the rest into a fuel system and tuning and it will run like a champ.
My car ran great at 4 psi with mild tuning and some fuel upgrades. No problems what so ever, then I dicked it up with a boost controller and a lead foot.
If you want to get into what you need to do to prep your car to run seriouse FI then 6K won't be enough to do much and the total price will realy depend on how much power you want to make and what your going to be doing with the car.
Biggest thing (imho)with prepping the car for FI is getting a well built lower cr motor under the hood. I went with a CR of 8.5:1 a mustang buddy of mine went with 8:1 both of us are shooting for over 600rwhp. Everything else is pretty standard for hotrodding out your car I.E tranny rebuild or replacement, new rearend.
I say go turbo because... I just like turbo's
and I've dumped as much money as I possibly can in to twinturboing my car for the last year or so and believe everyone should do the same.
In all honesty though it seems like the ATI and Vortech supercharges have less headaces assosiated with them.
Old Jul 16, 2003 | 06:52 PM
Jackstand's Avatar
thanks alot guys. Maybe all save about a couple more grand.
