e-85 help with boost
Old Mar 5, 2008 | 09:25 AM
Schwanke Engines's Avatar
LS1TECH Sponsor
I believe straight Ethanol has an "octane" rating of aroud 114.
They mix E-85 with the lowest grade fuel possible.
So, quick and dirty math
Max Ethanol in E-85 is 82%
85 Octane to denature is 18%
I know this is not exact, so don't shoot me over it.
114*.82=93.48
85*.18=15.3
93.48+15.3=108.78
Again, I am sure there is a way more complicated and scientific way to get to it, but it is the morning and I have things to do.
Old Mar 5, 2008 | 10:07 AM
Big Bird WS6's Avatar
Originally Posted by smokinHawk
yes you can run it at 9.5:1 or 9.8:1, my personal choice would be 9.5:1 and try to squeak out more boost, but you probably still could run allot on 9.8:1
ok. can i ask how you know this. like where you get your opinion from. i agree with you that i can run like 9.5 but i would like some back ground.
thank you
Old Mar 5, 2008 | 11:46 AM
rubbersidedown's Avatar
E98 is 111 (with denaturant). E85 is 105 to 101 octane (when it's e70 winter blend) Keep your compression about 9:1 on a fuely motor as you don't get the cooler intake charge because of the fuel cooling the intake like a carbed set-up. More boost will net you more power than simply raising the compression. We've run 11:1+ on 10 psi, but it's diminishing returns because of the octane level. e85 is 85% in the summer, depending on where you live, who supplies the fuel, etc. Most of the time it's around 80%
andy
Old Mar 6, 2008 | 11:32 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
From my E85 contact:
John,
As far as materials go we have found that billet aluminum is not a problem, most hard
alloys operate well with E85. The issue with aluminum is when it's soft aluminum. like
what's used in low quality die-casting. We also do not recommend the use of aluminum fuel
tanks for E85. Plastic tanks work much better, and prevent any galvanic issues from
occurring.
Rubber connectors are probably okay if they are not natural rubber but a composite. Viton
works extremely well as does neoprene, polyethylene and nitrile to name a few. Anything
that's Teflon coated or lined is excellent with high concentrations of ethanol, in fact
Teflon is probably the best material overall.
Braided stainless lines are fine, the important question is what are they lined with? If
it's any of the materials that I mentioned above it's good especially if it's Teflon.
Hope this info is helpful...
Mitch
Old Mar 6, 2008 | 12:00 PM
veee8's Avatar
What about the earlier stock steel tanks? Any adverse effects on those?
Old Mar 6, 2008 | 12:55 PM
great421's Avatar
Default Summer = 105 / Winter = 100
Up in MI there are three versions of E85 based on ambient temps for starting issues associated with the E portion of E85.
In the summer it is a 'real' E85 at 105 octane. In the winter, with the additional gasoline, it's more like E75 vs. E85 with a value of 100. So, moving from winter to spring (and also from fall to winter), the mix is also changed to move from E85 to more like E80 (at 102).
So, Winter = 100 (E75) / Summer = 105 (E85) / Fall & Spring = 102 (E80)
If you want consistancy where three different blends of E85 are formulated, in the summer a 50 / 50 mix of E85 and 87 gas will result in 96 octane, while in the winter the same net 96 # can be achieved by mixing 'winter' E85 with 92 octane gasoline. In the fall and spring - just use mid-grade.
Simple!
114*.82=93.48
85*.18=15.3
93.48+15.3=108.78
Old Mar 7, 2008 | 01:33 AM
ls1408cp's Avatar
psj good info. I am going to get a gallon of e85 and though some stuff in there and see what happens.
Old Mar 7, 2008 | 09:00 AM
smokinHawk's Avatar
thank you
from what i have read, there also was a thread here not to long ago talking about the affects of various compressions versus boost.
Old Mar 7, 2008 | 10:08 AM
i have had a gallon of e-85 sitting here all winter. cause this is what i wanted to run when i started the project. i put in some stianless, some aluminum and some carbon steel. the carbon is the only one that has changed at all.
Old Mar 7, 2008 | 10:10 AM
Old Geezer's Avatar
May be some info here....
http://www.turbobuick.com/forums/e85-technical-forum/
Old Mar 7, 2008 | 11:05 AM
2000 Tran Zam's Avatar
Originally Posted by Cchris1109
i wish they had E-85 in phoenix, arizona
I think the airport on chandler/mclintock sells e85...
Old Mar 7, 2008 | 07:01 PM
  #32
fletchls1's Avatar
I ran e85 all summer long and did not have any problems with it. I dont know if you guys are planning on mixing it or what when you say you have a gallon of it sitting around. I ran mine straight. ahhhh...the smell..cant wait until summer rolls around
Old Mar 21, 2008 | 12:59 PM
  #33
i mean i have metal sitting in a gallon to i can see corrosiveness. that is what i mean
