turbo experts come in...
Old Mar 12, 2008 | 04:56 PM
pozesd99''s Avatar
Default turbo experts come in...
im hoping to get over 1000rwhp on my set up so my question is if i can run my stock computer with just a 2 or 3 bar tune, and which one you'd chose
Old Mar 12, 2008 | 05:28 PM
Chiet_SS's Avatar
You can get a GM 3 bar map. I would say go with BS3 or AEM if you go AEM get the 3 1/2 bar map.
Old Mar 12, 2008 | 05:42 PM
pozesd99''s Avatar
isnt the big stuff 3 a 3000 dollar harness with program?? i am not sure on the standalones vs stock computer, is the computer capable of handling the 1000 whp with 2-3bar map sensor and AEM converter box for injectors?
Old Mar 12, 2008 | 05:44 PM
Chiet_SS's Avatar
I am sure it can be done. BS3 is around that. and AEM you dont need a resistor box to run low impedence injectors. there is a way you can wire them up without it. The AEM is all plug and play
Old Mar 12, 2008 | 05:53 PM
red beast's Avatar
I running a 3 bar map with stock computer with no problems, you should be fine....goodluck with your build.....
Old Mar 12, 2008 | 05:54 PM
pozesd99''s Avatar
hey red beast what did you dyno at
Old Mar 12, 2008 | 06:02 PM
red beast's Avatar
check pm....
Old Mar 12, 2008 | 06:24 PM
Cchris1109's Avatar
micheal run a stock tune with that car, it will yield more horsepower and insane MPG!!!!!!!!!!!!!!!!
oh and dont forget the 28 lbs injectors!!!!
Old Mar 12, 2008 | 06:51 PM
2000 Tran Zam's Avatar
im running 3 bar tune on stock pcm with rc 75# high imp. injectors...
I ran 933rwhp on 101 octane setting with my Duty cycle close to being maxed out... but ya with a converter box and low imp. 96's should do fine, maybe even 83's.
