HP Estimates?
Old Mar 12, 2008 | 11:41 PM
firehawk618's Avatar
Default HP Estimates?
My new setup is going to be......
EPP iron block 402, callies crank and rods, diamond pistons, patriot stage3 6L heads and studs, EPP Blower cam, SLP oilpump, CompR lifters, etc etc.
This should put me about 9.4:1 comp ratio.
ATI D1SC at about 14psi.....
6 speed trans with 3.42 gears.....
Only fuel system upgrage at this time is a Walbro 255, KB BAP, 60lb injectors....
Any ideas on what to expect at the wheels with a good SAFE tune?
Thanks.
Old Mar 12, 2008 | 11:54 PM
jz06man's Avatar
atleast 600-650rwhp
Old Mar 13, 2008 | 12:19 AM
Nice i'm sure fuel will be the limiting factor here.
Old Mar 13, 2008 | 02:24 AM
jz06man's Avatar
no you should be ok up to 650rwhp with what you have.... I only have BAP and 60lbs with TTI kit and it ran fine to 630rwhp- limited only by me and my tuning that we did not want to push it any more.... I have three stages
1. 585rwhp
2. 600rwhp
3. 630rwhp and no issues with fuel.... the issue will be behond 650 and really near 700 rwhp....
Good luck!
Old Mar 25, 2008 | 07:24 PM
Are you still running stock bottom end? If so how long now?
Old Mar 25, 2008 | 09:05 PM
Jake@EPP's Avatar
Depends on the dyno, Dynojet obiously alot higher, but a mustang i would safely say around 600ish to be safe.
Get a fuel kit like i sold mark and you should be golden!
Old Mar 25, 2008 | 09:36 PM
Jake,
Could you link me what you sold him?
Thanks
Old Mar 26, 2008 | 05:45 AM
EPP's Avatar
EPP
Talking
Thanks.
Now Mark said not to let the cat out of the bag on what you are doing... lol
I had a tooth split in half and had to get it pulley yesterday which is why I haven't replied to your pm's. I now have 37 unread pm's to reply to... Bob
