fi engine oil
Old Mar 17, 2008 | 07:22 AM
jmdgto's Avatar
Default fi engine oil
which oil do most of you FI guy's use. i am stuck between rp xrp and mobile both 5w-30. tks
Old Mar 17, 2008 | 02:59 PM
jmdgto's Avatar
does anyone use a different oil for their FI application or does FI require a different oil ?
Old Mar 17, 2008 | 03:03 PM
DanO's Avatar
nope.. just go with what the engine was designed for...
the only time you MAY consider looking into oil specifics is when your running a turbo and try to find out the best oil for that turbo.. but supercharged.. no issues.
Old Mar 17, 2008 | 04:20 PM
2000 Tran Zam's Avatar
I think I used 15w-50 for mine but it was cause the motor was built very loose...
Old Mar 17, 2008 | 04:37 PM
Websy21's Avatar
wow, thats some thick ****
Old Mar 17, 2008 | 05:02 PM
ddnspider's Avatar
Shell Rotella hands down
Old Mar 17, 2008 | 05:09 PM
bboyferal's Avatar
I'm using Mobil 1 20w-50
Old Mar 17, 2008 | 05:28 PM
hellbents10's Avatar
LS1Tech Sponsor
Rotella!!!!
Old Mar 17, 2008 | 05:29 PM
DMH Fabrication's Avatar
Another vote for Rotella
Old Mar 17, 2008 | 06:36 PM
BADBLUE02's Avatar
I'm still on the stock internals and use Pensoil 10w-30. My UOA's with 5W-30 showed it sheared quite a bit. A couple of people said they had lese shear with 10-30.
Old Mar 17, 2008 | 06:43 PM
52172's Avatar
rotella 5-40 synthetic
Old Mar 17, 2008 | 07:21 PM
DeltaT's Avatar
If you change your oil frequently, +1 for Rotella non-synthetic. The 5-gallon pail at Walmart is like $33 last time I checked, although it's probably $50 now
If you like to go 7500+ miles between changes, then the Rotella T synthetic.
Jim
Old Mar 17, 2008 | 10:11 PM
Websy21's Avatar
Holy rotella, I've heard the non synthetic reccommended several times for break in but haven't really heard anything for continuous use. This thread sounds promising, but I think I'd run the synthetic once its broken in. Easy to get and cheap. Hmmmm decisions, LOL
Old Mar 17, 2008 | 10:27 PM
ddnspider's Avatar
i run the synthetic and like it during most of the year.i may switch to non synthetic for the really hot summer months then switch back
Old Mar 17, 2008 | 10:39 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Castrol 5/50 synthetic has been very kind to my boosted work truck for 266K miles so far, so I also use it in the turboed GTO. I doubt that the results would have been much different with most other brand-name oils. However, some aftermarket builds have different bearing clearances, so I would leave the choice of oil weight to the engine builder.
Old Mar 17, 2008 | 11:03 PM
Project Dc2's Avatar
ive heard about using diesel motor oil on turbo cars also.
i tried some cheveron delo400 in my 1995 single turbo supra and i notice the car spools a bit better and overall i think drives smoother.
Old Mar 17, 2008 | 11:10 PM
Sideways240sx's Avatar
Penzoil plat 5w30.... Never heard about shearing issues. I may got to 10w30.
Chris
Old Mar 18, 2008 | 08:34 AM
ls1290's Avatar
Dumb Ass Vette Moderator
Mobile 1 20w50.
Keith
Old Mar 18, 2008 | 10:08 AM
Websy21's Avatar
Damn lots of opinions here, LOL - You aren't making it easy now
Why switch to non synthetic in the summer though?
Old Mar 18, 2008 | 12:09 PM
jmdgto's Avatar
yea now it is clear as mud. lol
By Brett Foote | 2026-06-04 05:00:17
