S91 fit problem read
Old Mar 18, 2008 | 01:23 AM
SuperZ's Avatar
Default S91 fit problem read
So back in 05 I bought from ProTurbo kits what was supposed to be a T6 GT-42 and we made the truck manifold kit including flanges.Im doing a 402 engine and turbo now so when i receive my new S91 it comes no where close to fitting apparently my old turbo was a T4 this whole time!!! So now that I have this massive turbo not only does the flange not fit but it does not clear the radiator! I can fix the flange situation but have already moved the radiator upwards.Does anyone know if the T6 version of the pte-t88 is still made.Im sure it would clear since its smaller.
Old Mar 18, 2008 | 07:24 AM
smokinHawk's Avatar
ya i think it is, give precision a call to know for sure and for lead time.
Old Mar 18, 2008 | 07:27 AM
BIG PURPLE's Avatar
Contact Jose @ Forced Inductions I Think He Can Help You.
Old Mar 18, 2008 | 07:51 AM
cablebandit's Avatar
i trimmed my core support about 1" to move my radiator/condenser forward and got my s488 to fit
Old Mar 18, 2008 | 08:38 AM
DrTurbo's Avatar
LS1TECH Sponsor
Yeah Jerry did the mod I would do. Trim and move forward. Also that doesn't suprise me about Pro Turbo. Apparently alot of people got duped bad by them....
Old Mar 18, 2008 | 11:38 AM
Josh@KY-Turbo's Avatar
Dude that that sucks ***. Have you cut the core support already? The pic below is a PT88 and it has tons of room. The S91 will fit in this configuration.
It's just a minor set back Bro.
Old Mar 18, 2008 | 11:53 AM
SuperZ's Avatar
Yes I cut the support and moved the rad up already but it duznt look like we cut it as much as that pic.Mine still has a little lean to it.I guess we could cut more and I could buy another new radiator.Is the pte88 t6 still good to put out some decent power levels?My goal is to be around 1k rwhp
Old Mar 18, 2008 | 12:14 PM
Bro Keep The S91 and make it fit. I have had a S91 in front of the engine and cleared the core support. It may require relocating the flange and setting the radiator back some more. It will be worth it in the end when you smash 1000hp.
Old Mar 18, 2008 | 12:17 PM
SuperZ's Avatar
I know your right i was just going to check on the pte 88 because it would be the easy way.I know MM made over 1k with his t4 version on a 364 cube motor
Old Mar 18, 2008 | 12:34 PM
I know Anthony Peck made 920rwhp with a T4 PT88 @ 21lbs on his 408 with stock 6.0L heads. It was a radical setup but made good power.
Here is the link:
https://ls1tech.com/forums/showthrea...ht=anthony+epp
Old Mar 18, 2008 | 12:42 PM
MIGHTYMOUSE's Avatar
i dunno your cubes but the turbo is 'good' for 1250 at the flywheel in t-4 flange.. i would bet that the t6 version is only slightly better at best but i have no experience with it.
i am getting every bit of it on a 364ci but boost is still stable so it could go some more.. i guess
Old Mar 18, 2008 | 12:48 PM
SuperZ's Avatar
Its going to be a 402.If I could make 1k rwhp on the t6 version I may do it.I would like to keep the S91 but i dont want to cut so much I lose even the hood latch and have to use hood pins.
Old Mar 18, 2008 | 04:19 PM
frcefed98's Avatar
Just cut the support even more. I cut my bro's support pretty severe to get his S400 BW to fit in front of his LT1 and we were able to retain the latch without resorting to other modifications like rewelding stuff.
keep the S91, and it'll be a better match for your new engine anyway.
Or just completely remake a new crossover....since you'll have to cut the T4 flange off anyway.
J
Old Mar 18, 2008 | 06:17 PM
black98ws6ta's Avatar
On a 400 inch motor the t6 will do quite a bit better, but the s91 will be a better mach. Ill send you a brand new t6 88 in trade for that s91...just a offer.
Old Mar 18, 2008 | 08:14 PM
SuperZ's Avatar
Looks like Parish also made over 1k rwhp with a t4 pte88 with a 408.Maybe the t6 would work for my 1k rwhp goal.
Old Mar 18, 2008 | 09:26 PM
Sideways240sx's Avatar
Cut the support to give you like 1/2 inch. Its hard to tell by this pic but i got a decent amount of room. Im far away from rad with turbo, and a decent amount away from crank pulley. a 88 would fit np. My turbo is a gt4276
Chris
Old Mar 18, 2008 | 09:41 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
Just keep the S91 and make it work. Post pics of how your radiator support is and we can probably give you a little more help.
Old Mar 19, 2008 | 01:35 AM
SuperZ's Avatar
Mine is cut out but just not as much as that pic.i guess I could just cut more and get another rad
