Need more suggestions with belt/pulley setup.........
The car makes 12psi with the K&N off, wants to climb, but the belt is destroyed before that happens...
ASP 7.85" crank 8 rib, 3.3" RR 8 rib, belts are done after one run, everything looks to be lined up right..
ScottWS6 runs similar pulleys, just a little bigger, and hes making more boost, and not slipping...
hes stock bracket, stock tensioner...
Everything I have is stock too...
Bracket flexing, tensioner too tight?
We are basically running out of ideas on what to do to get the problem solved...
Brian
the tensoiner is a good idea. maybe it would be worth putting a call into Sikora to see what he thinks but i do know alot of lt1 guys have solved belt issues with a spring loaded tensioner
It's one of three things:
#1 Bracket is flexing
#2 Alignment is off
#3 Your custom pulley shreds belts
I personally think it's a combination of #1 and #2.
I believe you mentioned that one side of the belt showed more wear than the other side?
Worst case you could see about having ZNines reinforce your bracket and other aspects of the kit.
Brian
check that your alternator is tight and not loose some how.
i also noticed that the type of belt makes a big difference. i used to use carquest brand belts , and i would get slippage and dust no matter what i do, it also would start loosing the ribs off the belt. on average i could get 2k miles per belt befor it either diseintegrated or snapped. when i switched to the goodyear gatorback belt i had none of the those problems: no slippage , very little dust since i put it on and the belt has been on for about 6k miles and it still looks like new.
