gt2-3 w/ APS
Old Mar 20, 2008 | 02:47 PM
SS101's Avatar
Default gt2-3 w/ APS
on a stock cube motor. anyone run this or know how it runs? with or without heads i don't care.
Old Mar 20, 2008 | 02:57 PM
ddnspider's Avatar
that cam loved nitrous.i know that for sure.youll probably be fine with the APS as its got alot of lift a high LSA and big exhaust duration compared to the intake to help spooling.
Old Mar 20, 2008 | 03:46 PM
Zombie's Avatar
I've never met a cam that didn't love nitrous
Old Mar 20, 2008 | 04:14 PM
ddnspider's Avatar
lmao how about picking up 140ft lbs of torque with stock heads+this cam and stock exhaust+a cutout on a 75 shot?? :happyy:
Old Mar 20, 2008 | 04:43 PM
Zombie's Avatar
lmao how about picking up 140ft lbs of torque with stock heads+this cam and stock exhaust+a cutout on a 75 shot?? :happy:
no problem, just spray at a lower RPM
Old Mar 20, 2008 | 09:50 PM
ddnspider's Avatar
but but but i read on the internet youre not supposed to spray below 3k
Old Mar 21, 2008 | 01:34 AM
tomz28's Avatar
i run a 04 zo6 cam i know its about the same i like it for right now its great on the street i all so run 12 psi
Old Mar 21, 2008 | 08:43 AM
DuronClocker's Avatar
A 75-shot should add 130-140ft-lbs of torque with any cam at 3000rpms
Old Mar 21, 2008 | 10:02 AM
SS101's Avatar
sounds like a plan! thanx for the quick input guys
Old Mar 21, 2008 | 10:30 AM
MY99TAWS6's Avatar
Lingenfelter on their site recommends either the gt2-3 or the gt-7 for supercharged or turbo applications. I also here they are recommending their gt-11 a bit now too but its not mentioned as recommended for super or turbo on their site . APS is running gt-11 with their forged up 346 of course they also have afr heads and fast 90/90 setup.
I am going to be trying out their gt-7 cam . I didnt' want to go up that much on lift and have to worry about changing out springs every 20000 miles or so.
Here are the specs of lingenfelter cams compared to z06 cams. They are very very similar. These cams are obviously going to be stealth and idle very close to stock idle,some guys say even mellower than stock idle. Thats fine with me.
01 ZO6 cam: 204/211 .525/.525 -116 LSA
Lingenfelter GT2 205/212 .540/.540 –116.5CL
02-03 ZO6 cam: 204/218 .551/.547 -117.5 LSA
Lingenfelter GT2-3 207/220 .571/.578 –118.5CL
05-07 ZO6 cam 210/230 .561/.557 –120.5 LSA
Lingenfelter GT7 208/230 .554/.546 –121CL
Anyone know what spec the 04 z06 cam had for specs. For some reason the dates skip over it. Mostly just curious. What I think they should do is a gt 11 cam with less lift around 580 or 590 with 1.7 rockers. Current gt11 is near 650 lift.
Old Mar 21, 2008 | 10:47 AM
02-04 all had the same cam.
That GT2-3 should be a good cam for you and should drive exactly like stock. I was going to go with that for my D1SC setup, but decided to go with Speed Inc's SC1 (222/228 114LSA) cam ground on XE-R lobes so it would sound at least a tiny bit like I had a cam
Old Mar 22, 2008 | 02:31 PM
ddnspider's Avatar
did u even bother to read the post?
Old Sep 14, 2008 | 04:51 PM
goober35's Avatar
I cant say with stock exhaust but i had the gt2-3 cam, hooker headers, off road y, LS6 intake, S2, intake, 3.23's and i made 357rwhp on LPE's dyno.
Old Sep 14, 2008 | 07:09 PM
ls1greg's Avatar
Boy is this thread old! Too bad I didn't see it sooner --> APS + GT2-3 setup.
It made something like 530 rwhp and 545 torque at 7.9 psi on 87 octane on EPP's dyno last December.
Old Sep 14, 2008 | 07:19 PM
MY99TAWS6's Avatar
So whats up with your car ls1greg? Did you send the turbos to aps or to anyone who works on turbos to see whats up with them?
Old Sep 14, 2008 | 08:22 PM
goober35's Avatar
Damn i dont even know how i pulled this thread up to the top. I guess i hit something wrong and skipped back 5 months.
Old Sep 15, 2008 | 08:52 PM
ls1greg's Avatar
First, I'm going to lower it and put on some nice wheels for aesthetics and traction purposes. Then I'm going to do some tuning stuff (sensors, gauges, injectors). When that's done, back to nitrous! When I can afford to, I'm going to have the exterior painted. After that, a new engine... I still need to make up my mind on exactly what I would like... and some fresh paint in the engine bay.
As far as the twins go, I'm going to send them to that guy in Texas who puts in the 65 lb/hr inducer wheels and ports the compressor housing for $1500 or whatever it was. He hangs around on the GTO forums. That won't be for a while though. There is so much rust, corrosion, and oxidation everywhere on this kit that I'm going to be spending a lot of time and money replacing those cheap oil lines, water lines, bolts, nuts, and washers.
