WARBIRD vs. QMP....the answers within....
my previous setups had tunes directly from fastchips and were retuned over $1000 total and i was never happy with them..
like i said i will dyno it wideband when the turbo kit can hold boost.
warbird.. my downpipe slides down constantly and im always up under it moving it back up and resetting the clamp.. that is ongoing.
i also blew the crossover where it goes into the back of the turbo manifold while racing, reason being i was told because i used a larger clamp than intended for that spot because the one that i did get I was not able to get around the pipe
rob, check my last post, i have the 3 legit unanswered questions that should be easy to respond to. what is the highest output built motor with your kit not counting your car,
why did you relocate the wastegate on the turbotech kit and dyno 707 when changing the turbotech plumbing would have been easier and nabbed you much more power,
and please ask ed wright how he tunes for the 85mm maf and for that part i will pay you.
and not to beat a dead horse but i am definitely not asking for tuning advice.. i just want to find out why the car isnt holding boost
i ran atap during my dyno's and was satisfied with the results that showed from my crappy street tune
so no need to adjust.. especially since im not getting any more air in the motor.------------------------------------------------
From WARBIRD:
I had a chance in the daylight to get a good look at it and that is exactly where the clamp let go. The clamp is still attached but the pipe has moved down and the pipes are no longer connected. This area has been a major source of leaks and no amount of adjusting has fixed it, and we used the supplied clamp, looks like we will have to find another modification to hold them together, unfortunately it can't be welded in that spot.
This whole thing gets more ridiculous by the minute.
FYI, I don't remember where I said I blew it off, with the pipes seperated yes I am now running open exhaust. I have no cats, 3" ID exhaust and a BB triflow on the back.
Simple for you: turbo no boost, engine cold, no heat, Hmmmmmmmmmm sounds like the turbo is the issue to sort out.
A few quick points, and I'm outta here
Mac header on pass side, Log manifold, crossover from Mac header and 3inch downpipe after the turbo. Thats it AFAIK
He is running a B&B catback which is highly restrictive IMO at his power level.
BTW I again I am not taking sides in any of this, just providing info as an observer and someone who has driven/raced the car.
Chris
Geez...you don't even know what pipe blew off your car! My fault, "separated" from your car.
What issue did I "skirt"??? I said, bring me your car, if there's soemthing wrong with it that's our fault, I'll fix it FREE. FREE I said!!! Are you afraid of what I'll find?? Me thinks so.
Step up.
Ah man thats gonna get me a warning or a ban
After the clamp mishap
it went down to where it was preturbo between 165 and 175 the whole time. I would just like your thoughts on this. I am not trying to flame at all.
Thanks,
Chris
1. Rice ETR, do you even have a kit? Or are you just MM spokes person? Seems like he is a big boy and can handle himself
2. MM why are you so hard headed about getting the car on a dyno to check your A/F instead of using Autotap. Pretty well known the stock O2's can't be used to tune. That has been established time and time again. As much money as you have shelled out for your engine, turbo kits etc buying an aftermarket O2 so you can tune on the streets should be chump change. Common sense, you need a wideband to tune.
Another thing, as much trouble as your having why didn't you take Robs offer for getting your car running? You claim the only thing your worried about is holding the boost,Rob could of have done all the troubleshooting and right now you would be enjoying your car!
3. Warbird why in the world did you pay ARE to do the install and you keep tinkering with it. Why dont you let them figure it out, thats what they were paid to do, correct?
I believe he is installing either a high flow muffler or cutout soon so it would be a good experiment to see what happens...
I see Rob offering to go through the car. I am NOT a turbo guy, but I have to say that Rob has not only run 9's in his GN, but he's ran 9's with a turbo LS1 like three years ago. He's shown to me a strong knowledge of how to set up turbo cars. If I had one of his kits I would not ignore his comments about wastegate placement, I would do exactly what he says. As a tangential comment, I know that tuner kits can end up being the bane of one's existence. Selling 1/2 of normal kit to someone who then has issues is frustrating. There are a number of unknown parts that they did not source so they are at a disadvantage when it comes to addressing problems.
I see Warbird's Triflo as being restrictive.
I see MM's not using a wideband as being too thrifty, but potentially at the expense of not figuring out stuff.
I have no seen either individual post an entire list of their mods which would help in figuring out whether or not they are hitting their goals.
1- Lots of this just looks like he said she said things. Stop arguing about symantics by using realworld factual information. Not well soo and so said this so it's fact etc...
2- Warbird realize that you might be pushing a kit well above its engineered limit. Robs own admission says he has a customer running 14psi. Are you really trying to run 25-30psi? If so realize in the realworld going to a level where others have not tried with the parts you have will without a doubt cost enormous amounts or time and money.
3- Also look at the product you bought. No where could I locate any promised results of any kind. I mean really would you buy a car with no Mpg estimate or for that matter know anything about the engine etc?
4- Have you ever met import guy that had a 500hp or 1000hp fuel pump? I have and not for minute did I think "Oh he must have 1000hp or 500hp". Just because you have a turbo or fuel system to produce huge number does not mean you will be able to reach those goals. Everyone who works on cars knows that your car is only as good as the weakest part. I know you might have hoped that the kit would hold up, but certain parts may not have.
So here is where this whole mess is...
You bought a kit with no gaurantee of results with no written documentation of what will be warrantied if anything. Huge I mean monumetal comsumer mistake. Con artists make millions off of consumers that buy first and ask later.
Rob's kit could be a very nice product and it certainly seems so with nice shiny bits to please the eyes. Rather then complain about a kit that doesn't do what you wanted it to do. You should take full advantage of that someone that sold you a product with no warranty or gaurantee is even around to work with you on the issues.
Tell me you really didn't take a car that you knew wasn't running well to the racetrack?
If so thank your lucky stars your car isn't in the wall or with a blown motor. Also what about your safety? I mean really would you take a car with a tire full of fix a flat 200mph?
chris, again i appreciate you tuning insight, lord knows you are up there with the best of them, but i am NOT looking for peak hp here, im not looking to nail down the perfect tune.. im just trying to get a fundamental quality of turbocharging to exist on my car.. holding boost through the rev range. soon as it holds boost, ill take it to the best mustang dyno with wideband i can find within a few hours drive
a small leak,(this one i cannot hear, only see carbon deposit on the lip of the flange) would only minorly slow spool time, nothing more.
rob, its frutless to talk about past tunes when the current tune isnt even the issue. for the record, no i was sent a generic turbo tune from him just like you sent out for your turbo kit.. and it pinged like mad at 4psi boost.
-i have dynoed only one time(3 identical pulls) the place had no wideband or of course i would have hooked it up.. not everybody has a wideband.
-warbird and my downpipes have both blown off, that is 10% of your 20 kits sold right there, and we are so far the only ones to publicly run built motors at the track.
i also appreciate you overnighting me that clamp, it was in the box with the 8 intake side clamps that were completely wrong.
thanks for answering those questions. though im not sure why you are taking shots at me, im just looking to make my car run like it should. in response i have called are to re-discuss the heads (which flow numbers i posted a couple days ago) and discuss the cam.. unfortunately are is currently on 'summer holidays' according to the answering machine, so further answers will have to wait.. the others i have allready answered.. no exaust leaks significant to cause boost to drop, that would have to be monsterous.. otherwise it would only affect spool time. i have no intake leaks either, and again no one can show me how tuning will make boost go down vs. rpm.. if they could, i would gladly build a tune following exactly what they say and try it immediately... but they can't so i'm not going to... because a systems ability to support a created boost level cannot be related to a/f or timing within normal working boundaries as i obviously am.
sscam: jarrod has been around since i parked my car in his garage to install the kit.. he knows it in and out as well as i and has had great sucess with his turbo mustang. his views are not protecting me, they are completely independent, although identical. as for me i know i dont have a perfect tune and i know to get one i need to be on a wideband.. no problem.. but im not wasting money on one if the car wont hold boost.. and that has nothing to do with tuning, or as yet has not been proven to have anything to do with tuning... i have never read anywhere how a pretty good tune can allow boost to drop off in an appropriately sized combination and a perfect tune on the same combination holds boost perfectly.. it just doesnt happen like that in a turbo set up.
lastly, rob offered to work on the car when the first manifold sent out was built wrong. that is completely different happening from what i'm dealing with now. i didnt take him up on it because not everybody (not me) had the time or money to get ahold of a trailer and take off work for the couple days that it did fit in his scedule to look over it. robs busy, im busy, it never matched.. i do not know why he needs to bring that up now, as it has nothing to do with the current issue.. asside from the fact that his new turbo kit allready has a history of issues.
woooha
How the hell did your downpipe blow off? On the QMP site the picture shows it bolted to the turbo housing.
What psi were you at?
If it is not that location then where was the seam that seperated?
If it was not attached with bolts then how was it attached?
Be extremely specific and post pictures. That should get you some help.
IMO the best thing to do at this point is figure out how to get the car to Rob and have him take a look at it. Not for the tuning, but for the boost problem.
Established: Warbird is a loser that never has, nor ever could turn a bolt on his car. Clearly this establishes how he is an expert on all things... ghey.
Established: Rice Eater has never built an LS1/LS6, and the only turbo car he's ever claimed to own had such poor output, that even my personal friend, with whom I work, produces better 331 N/A numbers, and that's without a tune.
Also Established: Rob is the ONLY on that has successfully campaigned a high-horsepower car with no issues, and lesser equipment than the above-mentioned losers are using. Though, in their defense, MM and Warbird have improperly installed and poorly tuned their cars, if in fact, one can classify their stupidity as tuning.
As yet to be seen: I've just received my Yank PT3400/Rossler 4L60E today, 31Jul03. It should be installed within 2 weeks. I hope it is, because I have two arranged matches, as follows:
95 Mustang, 331, 200 shot, 3.73, Tremec T5, 3500lbs.
LS1 Hawk, H/C, full exhaust, intake, 5# Procharger, claimed 420/427 on a Mustang (though we know that the numbers actually suck because centrifugal S/Cs are crap for REAL TQ/HP.
All this potential in my car with a mere, (blow the MM crap motor sky-high, because he ups the boost with no tuning to speak of) EW tune. This tune of course, being a direction I did not originally wish to pursue, however, when I found out how lame the crap tunes are from my original tuner, I just had to go with the best aternative. That would be EW.
As I stated previously: "I'll scan my times in forthwith." For you MM, that means, "as soon as I have them." And when I have my times, I can GUARANTEE you that they'll be better than 18lbs/125mph and 11.8xs. :p
BWAHAHAHAHHAHhahahahaahahahahha!
So Long!
SC-
FWIW: My personal apologies to Rob. He deserves apologies for putting up with the stupidity, ignorance, and comtempt shown by two customers that have NO CLUE of how to make a real car run, and one other idiot, that never has made a car run, much less an LS1... (For the record: MM - Dave Childress - VA, WarBird - (Paul don't know about cars, but can type alot about nothing) - Canada, and SomethingEater (never had a car that had any power but has alot to say about nothing that he's ever understood) - VA.
You have made a valid point, and asked a good question. As to taking the kit off my car, got too much into it to back down now. For the most part the car works great and is very reliable and the support of ARE has been fantastic.
What are so convinced you are going to find? Tell me, my gaskets are on right, I had all my engine tolerances checked, it's been leaked down and I have the flow numbers. I have seen this engine put together start to finish and I know exactly what's in it. You are so sure it is the engine will you admit your turbo has a problem if everything checks out. I made you a legitimate offer at the beginning of this thread and you totally ingnored it. I offered to take the car to any third party for a tear down. Give me a hint of what you think is wrong and I'll have it looked at.
Put your money where your mouth is.
Paul
Ok hold the horses here.
Evidence is supposed to point to a greater truth and is refutable.
Do not work with evidence.
Work in Fact
I am merely a third party speaking out about what i have seen and know about this kit... if i don't belong in here, then you definitely don't...
what?.... what's that?... you don't have one?...what?...
Yea... his tuning is just horrible...
