working on 67nova with twins and dual fuel, lots of pics.
Old 03-18-2009, 08:57 PM
  #121
blazin's Avatar
Where are you guys going to dyno at? Id like to come check it out.
Old 03-18-2009, 09:20 PM
  #122
single digit dreamer
parish8's Avatar
c@s in omaha
Old 03-31-2009, 02:09 AM
  #123
03supercharged's Avatar
Any news?
Old 04-01-2009, 12:21 PM
  #124
cause4panic's Avatar
Originally Posted by parish8
Can you explain the fuel system a little more? You have (4) walpro 255's for the main fuel and a single 255 for the meth?
Old 04-01-2009, 07:20 PM
  #125
parish8's Avatar
Originally Posted by 03supercharged
Any news?
yep. the 4 injectors in the elbow are not working for our daily driving. we are putting in 2 sets of 8 injectors right in the intake runners. we should have that taken care of in a few days and be ready to give it another try.
we are going to keep the 4 in the elbow and eventually run meth through them.
the single pump is for pump gas. the 4 pumps are for meth/e85/racefuel.
Old 04-10-2009, 01:35 PM
  #126
tirefryin_s10's Avatar
any updates ?
Old 04-12-2009, 11:24 AM
  #127
T TA 355's Avatar
I found a place with cheaper weld els I will see if I can find it again. How much are 6.0 going for around there?
Old 04-12-2009, 11:45 AM
  #128
T TA 355's Avatar
Kingmetals.com
Old 04-12-2009, 05:30 PM
  #129
T TA 355's Avatar
acestainless.com
Old 04-12-2009, 08:15 PM
  #130
parish8's Avatar
Originally Posted by T TA 355
acestainless.com
those are some good prices. i will give them a try next time.
sometimes the mandrels are not really mandrels. it sucks when you cut a 90 in the middle and try and clock it and now you are welding 2 oval pipes together. the stuff from verocious is great to work with. i tried some stuff from summit that was from "pypes" it sucked. when cut part way thru a bend it turned into some oddball shape.
Old 04-12-2009, 08:16 PM
  #131
parish8's Avatar
the cheapest 6.0's are around $800. that would be something like an 01 with 100k on it.
Old 04-14-2009, 12:14 PM
  #132
bbeck's Avatar
Watch craigslist, I just picked one up for about 500 bux. Mine came with the wiring harness and the computer. Mine has just under 100k on it.
Old 04-25-2009, 11:31 AM
  #133
parish8's Avatar
haven't been getting a lot done lately but things are coming along. had to work threw a few problems.
the 4 injectors in the elbow didn't work well. we were getting lean farts and big back fires at the same time. a/f ratio was all over the place. you can see where we put a plastic cover over one of the tb holes so we could look in there. we tried a few things but it wasn't working well.
after that we decided to just do 2 full sets of injectors on the intake. we did most of the work ourselves and it turned out nice. had to get a little help finish welding the bungs. also had to do a little wiring to the squirt to support 16+ injectors.
we had a mishap that could have been ugly. when putting the squirt together one of the components on the board got pushed over and caused a malfunction. the 8 primary injectors were permanently grounded. that means any time the key was turned on the pump would prime and power would go to the hot side of the injectors and fuel would just flow into the engine. all we knew was we couldn't build any fuel pressure so we turned it on and off something like 20 times. after we figured out the pumps were pumping and the fuel was going somewhere we kind of got freaked out. where did all of that fuel go? oh ****....
we pulled one plug and fuel poured out like a garden hose, and it kept pouring out for awhile. soo, next we found the squirt problem and fixed it, pulled all the plugs, drained the gas out of the cylinders, changed the oil and the plugs. fired it up and retuned for 8 primary injectors.
now it fires right up, idles smooth and quiet revs nice and clean. a/f ratio is steady, tuning is easy. WE ARE NOW READY TO HIT UP THE DYNO(or street if we were all legal)!! woohoo!
it is starting to look kinda busy under the hood but i think it still looks good.
Old 04-25-2009, 01:30 PM
  #134
eviltwin_1987's Avatar
awesome. talk about a fuel system
Old 04-27-2009, 12:30 AM
  #135
djsanchez2's Avatar
How much did it dyno?
Old 04-27-2009, 06:22 AM
  #136
parish8's Avatar
we made it to the dyno. working thru the tune with the primary fuel system/injectors was easy. got up to about 5psi on pump gas. dyno was showing 402hp at 5500rpm and 5psi and was still going up fast. not bad for no intercooler and not peeking out yet. timing was at a conservative 15deg.
then trying to do the fuel phase we ran into problems. we could get the 2nd system to come on and the 1st to fade. seemed like it was going to work but once it tried going 100% to the 2nd set up it would start pulsing. i suspect one bank of the injectors were not on at all or a fuel pressure issue but it was too late to look into it. might just need to work that part of the tune more till it is perfect.
Old 04-27-2009, 06:41 AM
  #137
chuntington101's Avatar
just thinking about your build, and having no intercooler, have you thought about pre turbo water/meth injection??
Hope you get the phasing between the first and second fuel systems sorted.
Chris.
Old 04-27-2009, 06:45 AM
  #138
98Camarod's Avatar
Were the injectors logged or is it possible to even log them with your setup?
Old 04-27-2009, 09:51 AM
  #139
parish8's Avatar
pw/dc1 is primary fuel system
pw2/dc2 is 2nd fuel system(race gas or meth)
you can see our 2 ve tables, you can see it trying to make the switch. after this run we tried a quicker change over. we tried making he change at a lower kpa just to make sure we were not hovering right at the wg spring pressure and switchover pressure at the same time.
right now i suspect a fuel system problem on the 2nd system but if that isn't it then we just need to work on the change over tune area more. we are having fun and will get it figured out soon.
Old 04-28-2009, 04:54 PM
  #140
parish8's Avatar
kyle got a few new pics of the car while we were at the dyno >> http://www.1320video.com/gallery/DynoSport4-25?page=2
Quick Reply: working on 67nova with twins and dual fuel, lots of pics.
