restricted intercooler???
Old Apr 13, 2008 | 12:20 PM
RaySS138's Avatar
Default restricted intercooler???
my friends car hit the dyno the other day running an F1a and a big front mount intercooler on a 408. the IATs were close to 130! and he was only seeing 12 psi at the motor (boost gage and data log) he checked the boost at the inlet of the intercooler and he saw 18-19psi at the inlet side. he pulled it off and cant see anything wrong looking into the inlet and outlet, anyone have any ideas on what is causing this big restriction and the high IATs.
Old Apr 13, 2008 | 12:40 PM
Drew04GTO's Avatar
The intercooler is too small.
Old Apr 13, 2008 | 12:47 PM
MonochromeSS's Avatar
How big is big?
Old Apr 13, 2008 | 01:04 PM
Pat-Man's Avatar
I'd say his IC is too small as well. Do you know the dimensions of his intercooler?
Old Apr 13, 2008 | 01:44 PM
RaySS138's Avatar
24x12x4, the same size has been used on over 1000rwhp without any issues
Old Apr 13, 2008 | 01:55 PM
forcd ind's Avatar
thats a pretty big boost loss-is it an ebay i/c, or a good one?
if in fact its putting out 18 lbs boost, i dont think the at's are that high-i did some testing a few years ago, and at 18 lbs boost, the outlet temps were 330 deg., and the temps out of the i/c were 189 degs
Old Apr 13, 2008 | 02:29 PM
RaySS138's Avatar
with this size intercooler he should be seeing IATs just over ambient it was a cold day also, I believe he told me its a chinese manufactured intercooler. whats inside the intercooler that could be bad to cause this restriction?
Old Apr 13, 2008 | 03:01 PM
ddnspider's Avatar
sounds like a leak or something.to be dropping 6-7 psi from a big FMIC like that sounds odd
Old Apr 13, 2008 | 04:12 PM
RaySS138's Avatar
the IATs are extremely high though, and the tubing to the motor after the intercooler is not leaking.
DeltaT's Avatar
Could also be a throttle restriction - he needs to check the pressure right after the FMIC as well to determine whether it's the IC or after that.
Jim
Old Apr 13, 2008 | 04:15 PM
ddnspider's Avatar
i meant a leak in the FMIC itself.someone else on here had that problem
Old Apr 13, 2008 | 04:23 PM
Pat-Man's Avatar
pressure test?
Old Apr 13, 2008 | 06:53 PM
RaySS138's Avatar
im trying to figure out how we can do this in the garage, he could take it to our local machine shop maybe, how much restriction should there be?
Old Apr 13, 2008 | 07:50 PM
EPP's Avatar
EPP
I'm going to next day Jon the intercooler off of my Camaro tomorrow, to see if it is in fact the intercooler. Mine was keeping the iat's nice and cool, and we were seeing 18 psi during the heat of the day with basically the same combination that Jon has. Bob
Old Apr 13, 2008 | 09:14 PM
RaySS138's Avatar
he mentioned that today, thats pretty awsome of you Bob, hes really bummed out about this right now. if its not the intercooler what else could it be? hes running a stock throttle body, but that cant be the issue. what do you mean by a throttle restriction? the tps showed 100% open. could it be the bypass valve? I dont see how that would cause high IATs though, maybe a boost leak or something.
Old Apr 14, 2008 | 08:10 AM
blake culp's Avatar
for a simple pressure test run to the hardware store and pick up two PVC caps that will fit inside your silicon intercooler couplers. Then pick up some auto valve stems at a tire shop. Drill out your PVC pipe caps so the valve stems fit, one in each cap, put the caps in the intercooler couplers so its completly sealed and fill the intercooler with air, put a pressure guage on the other end. It should be obvious if you have any leaks. Be careful you dont overpressure your intercooler and blow it up, i think 10-15 psi would be safe and easily show if you have a leak. It might be a good idea to put it under a sheet of plexi glass or something just in case.
Old Apr 14, 2008 | 08:41 AM
Old Geezer's Avatar
Take it to a radiator shop, and have it tested...
Old Apr 14, 2008 | 04:25 PM
99.9percenter's Avatar
Originally Posted by Exotic Performance Plus
I'm going to next day Jon the intercooler off of my Camaro tomorrow. Bob
Bob please send me the shirt off your back!. Thank You!! -Tim
Old Apr 14, 2008 | 08:28 PM
EPP's Avatar
EPP
Jon will have the intercooler tomorrow, hopefully it will take care of the problem. Bob
Old Apr 16, 2008 | 01:56 PM
RaySS138's Avatar
we got bobs personal intercooler and put it on, took the car out and made around 17psi going sideways the whole time, so we were thinking it must have been the intercooler, for the hell of it we put the other one back on and we made the same boost??? (going sideways again). so we now know that its not the intercooler, and we are pretty sure that it was 2 of the pipes coming out of the intercooler that may have been pushed too far together into the silicone coupler at an angle to each other and restricting flow causing the high IATs and low boost. Im glad its not the intercooler as im sure Bob and Jon are too. Bob, thankyou for all your help with this and im sorry if I caused you any problems posting this up before we knew what was going on for sure.
