Help with my STS Kit.
Old Apr 15, 2008 | 02:28 PM
charlie c5's Avatar
Default Help with my STS Kit.
Was wondering if cutting my little gold resister out and basically bipassing it would hurt anything. Talked to a guy from STS, and he said I would have no problems at all. The STS oil pump was made to run at high speed all the time, the resister was put in the kit to quieten the pump down at red lights and when the car is stopped and the high oil pressure isn't needed.
Second. whats an FMIC, and what does it do.. ?
Thanks
Charlie
Old Apr 15, 2008 | 02:38 PM
GMLIFER's Avatar
Don't know about the resistor but an FMIC is a front mount inter cooler....
FMIC brings intake temps down alot.
Old Apr 15, 2008 | 02:42 PM
charlie c5's Avatar
Well, I've got the twin Procharger intercooler set up. Guess that's good enough... Thanks for your help...
Old Apr 15, 2008 | 06:00 PM
ssdriver27's Avatar
yes you can cut out the resister I would recommend to in fact. ~Guy
Old Apr 15, 2008 | 06:28 PM
OUTLAWZ RACING's Avatar
I did it allso long time ago. The pump was loud when cold but when hot it was quite, Plus the 4 1/2 dump back there I couldent really hear it.
Old Apr 15, 2008 | 06:30 PM
koolaid_kid's Avatar
Check your IATs to see how efficient your intercoolers are. Ideal temps would be ~10 degrees above ambient.
Old Apr 15, 2008 | 09:21 PM
NYSS Guy's Avatar
I cut the resistor out too....it'll be fine. How much boost are you running through it now?
Old Apr 15, 2008 | 09:29 PM
charlie c5's Avatar
I'm setting at 12.5 lbs of boost, and a little meth to help.
Old Apr 15, 2008 | 09:32 PM
NYSS Guy's Avatar
Sweet. I agree with above though...make sure those intercoolers are keeping up. Good luck.
Old Apr 16, 2008 | 11:39 AM
ssdriver27's Avatar
shoot Im runnin 12 psi and with a 31" x 12" x 3" on an sts setup Im seeing about 20 to 40 degrees above ambient. I wish I was ~10. but then again Im running the 60-1 maybe it wouldnt be so hot if I was sportin the 67 or 70.
~Guy
Old Apr 16, 2008 | 08:00 PM
96BIGBODY's Avatar
Cut mine too..
Old Apr 17, 2008 | 08:20 AM
geeteego's Avatar
FMIC is a good idea, although it increases boost saturation with STS. (English - I see about 2.5psi less boost at the manifold than I do at the turbo, measured simultaneously. I have the STS intercooler)
Are you tuning for meth?
And yes, + another on cutting out the resistor. All it does is get hot under the hood and switch the pump to low output. You may end up needing an in-line oil restrictor, however.
Old Apr 17, 2008 | 05:59 PM
vandal0-0's Avatar
Can't you just hook the two wires together on the hobb switch and it will run on high all the time.
Old Apr 18, 2008 | 07:48 PM
smoke20's Avatar
guess i have been lucky going on year 3 with the kit and the resistor hasnt been a problem, during the winter when its cold i switch over manually to the high press but in summer i run it on low with the hobbs switch turning it to high after 1 psi boost is seen, as far as the intercooler goes if you put a boost controller on and reference from the manifold it wont matter the pressure drop at the FMIC it just cranks more boost to match what your asking for,
Old Apr 18, 2008 | 07:51 PM
smoke20's Avatar
~Guy
by the way what kind of #s are you putting down at 12 psi?? and who do you use to tune your car in monroe, im in spokane and i will need a retune later this summer after some mods.
