Procharger Power #'s
Old Apr 27, 2008 | 12:08 AM
Spade's Avatar
Do you have a dyno sheet? I would like to see your power band with that cam.
Old Apr 27, 2008 | 11:22 AM
badass99ss's Avatar
Here ya go.
Troy
Old Apr 27, 2008 | 08:03 PM
Spade's Avatar
Originally Posted by badass99ss
Here ya go.
Troy
Thanks bro
Old Apr 28, 2008 | 05:11 AM
EPP's Avatar
EPP
Thumbs up
Hey Bob whats the going price for a Moser set-up?
Thanks
Troy
$2,500.00 will get you a Moser 9 inch with the better Truetrac and lower control arm relocation brackets installed. This includes shipping! Bob
Old Apr 28, 2008 | 02:10 PM
badass99ss's Avatar
Here is a short vid.
http://www.youtube.com/watch?v=UCUQK_PKmyY
Troy
Old Apr 28, 2008 | 05:53 PM
LS1RedZ's Avatar
Im in the same boat as you. I need a fuel system big time. Running out of fuel at 6k.
Oh yeah.. Do you like the 4:11's? I have the same gears, but I wanting to switch to a 3:73.
Old Apr 28, 2008 | 06:31 PM
badass99ss's Avatar
The 4:11's are a love hate relationship. I love the acceleration they give you but the short 1st and 2nd gear can get anoying. When I upgrade the rear I was thinking of 3:73's as well.
Old Apr 28, 2008 | 10:11 PM
dcvingv6's Avatar
congrats man, i was waiting to see your results, as you have a somewhat similar set up to me, right down to the stock bottom and 10 bolt!! (my tuning is friday!). Definitely looks like your running out of fuel on top.
Great numbers, and good luck!!!
Old Apr 29, 2008 | 07:08 AM
AFASTYZFR1's Avatar
I had a similar set up on stock bottom (with alkycontrol) and my block is at EPP getting some new parts
also have SDCE on the way set up for 15psi
Don't beat on those stock bottom ends too much....my car only had 25k miles and only 5k miles were at 600rwhp
I have a great tuner and motor still ran and didn't make any noise when it was pulled, but compression on cylinder #5 was 90psi
also killed the 10 bolt and never launched it at the track
Old Apr 29, 2008 | 07:21 AM
Rickys S/C Z28's Avatar
nice numbers man!! how did you get 8 psi out of that thing?? i have a 4in crank pulley and a 3.20 head unit pulley and can only man 6.5psi?? what am i doing wrong?
Old Apr 29, 2008 | 07:40 AM
rufretic's Avatar
Wow, I don't understand how you guys get such low boost, maybe it's just the P1. My D1 with a 4.25 pulley was boosting 14psi. Your at a much more reasonable amount of boost though. You should be real happy in the 500s. I wouldn't go more than that until your ready to have the engine built. Mine made a ton of power but the stock bottom end was short lived, I did get a bunch of low 10 second passes though so that was cool.
Old Apr 29, 2008 | 07:47 AM
  #32
rufretic's Avatar
It's your small 4" crank pulley, that's really small. I think mine was a 7". If you go to a larger crank pulley you could also go to a larger pulley on the head unit and still make more boost with less chance of belt slip. Do you have the ati damper? I have a brand new 8 rib pulley that I think is 7" that will bolt right to the ati crank pulley. I don't need it because with my new setup I'm going cog. If you want it pm me.
Old Apr 29, 2008 | 11:39 AM
  #33
i need a bigger crank pulley thats for sure!!, you have a pm sir
Old Apr 29, 2008 | 12:00 PM
  #34
badass99ss's Avatar
Thanks man. What fuel system are you runing? Good luck on Friday, let me know how you do.
Troy
Old Apr 29, 2008 | 08:20 PM
  #35
dcvingv6's Avatar
Troy
I am running the Nasty Stage 2 street kit, its a hotwired racetronix pump, its a 340l I believe, -6an feed with there billet rails, 60lb injectors, boost referenced AFPR and a -6an return.
I hope it will suffice with the stock bottom. When i have the motor done, i am going to switch to a double pump setup on a hobbs switch.
We shall see how it goes on Friday!!
Thanks...
--Mike
