ProCharger air to water 1800hp intercooler being added to EPP Camaro
#61
the SDCE uses a 7.25, I usually see around 7250 through the lights in the 1/4 so thats about it for the F1A. I have tried a 3.7 pulley for 1/8 mile but it gets too hot for me.
With the 3.9 at 3800DA a couple weeks ago I only seen 15.6psi @ 7000rpm which is a little lower than I expected. Car ran 5.82 @ 122 in the 1/8 which isnt bad for that weather and the tires being gone (1.31 60') plus I added 100lbs with the 25.5, air shifter and fire system. But I was hoping to get to London Ky in some cooler weather tonight with some new tires. Its possible I may be running into some inlet restriction with the bigger engine also, boost seems to level off pretty early but maybe the blower is just done also. But I need to get into some better air to see and thats tough around here this time of the year.
#63
#65
#66
Were pushing for shaking it down wendsday and then running the NMCA bowling green race.
It looks very nice, and yes there is quite a bit of fabrication to make this work. In house only
We put it in the nose due to the huge wheelie we pulled at the shoot out, and just trying a few things here and there.
Looks good guys! So what's next, an F3 & 7 second slips?
#67
I think the transition to the w2a is not that much heavier then the a2a. The core+brackets weighs in around 30ish + water. Thats the killer right there, dang water weight and the pump/tank/lines, but iat's that are less then ambient arent to shabby
#68
1800, 2000, air, ati, camaro, epp, f2, hp, intercooled, intercooler, intercoolers, pn, procharger, sold, water, wi1005a001
