pt88
Old Apr 27, 2008 | 08:41 PM
cjg454ss's Avatar
Default pt88
just got my new pt88 in and when i bolt it up the cold side outlet is facing the motor, if i rotated it by loosening the vband the oiling system moves with it so im guessing it will mess up the oiling of the turbo, what can i do? maybe a 90* off the out let?
Old Apr 27, 2008 | 08:57 PM
veee8's Avatar
On my T6 4788, you can rotate either side, leaving the center section stationary. V band on both sides.
Old Apr 27, 2008 | 09:01 PM
MIGHTYMOUSE's Avatar
you can rotate it all
loosen the bolts on the back of the cold side cover w/ 10mm wrench
Old Apr 27, 2008 | 10:20 PM
red83's Avatar
From: sneaking in your back door as you leave!/cartersville ga
x2. i think there is 8 or 10 of them. i cant remember excactly. they are in sets of 2
Old Apr 28, 2008 | 12:07 PM
cjg454ss's Avatar
thanks for the help guys, ill try it after work today.
