Turbo sizing,backpressure explained
How do I change this text
thread from the dead again, but why would it matter where the gauge is mounted? Take my STS truck for example. I have a back pressure gauge mounted in the rear 02 sensor port, why would it read any differently if it were closer to the turbo?
Edit: Now that I think of it, a 0-restriction intercooler will actually add a tiny bit of exhaust pressure due to increased mass flow through the compressor and the corresponding drive pressure needed by the turbine.
If it's the same amount of air at the same boost pressure, then it's the same drive pressure. However, adding an intercooler adds restriction to the cold side and also increases air mass flow rate, both of which increase compressor required hp and, thus, exhaust drive pressure.
True, but less drive pressure does result in more hp for the same boost.
Oddly enough, something like a maf delete or bigger throttle body actually helps power on a turbo car by lowering drive pressure. It's counterintuitive but the end result is still more power. It works different on a supercharged or na engine.
