New Turbo TC product update
#45
sounds fair enough. I am gonna put some more miles on mine the way it is then upgrade. Right now I'm dealing with broken drivetrain stuff cause the little 76 is cranking out so much power. Got a fabed 9" on order along with new driveshaft. First the tranny blew up. Now the rear. Burned up two clutches also rated at 600+ horsepower so I said **** it and went with a 2500 dollar twin disk that grabs harder the hotter it gets.
#49
We now have the TC series units guys offered with the new 78mm comp wheel. This should get some of you guys that are wanting a few more ponies satisfied. Check it out in the site link below...
http://forcedinductions.com/productturbonetics.htm
is it possible to put the 78mm comp wheel into the gtk 1000 front cover?
how will it flow?
thanks
ash
#55
well I put down 700 on only 10 lbs boost on a 348 with an M6 and 10 bolt. So the potential is there. If I were to up the boost to say 17 lbs that would add 175 rwhp and subtract 100 rwhp with a 4l80e and 9" and you would be at 775 rwhp with a heavy duty auto and drivetrain. Thats a guesstimate.
