I want a LOUD FI setup (blower whine/turbo whistle)
Re: I want a LOUD FI setup (blower whine/turbo whistle)
You guys run close to the same #'s as H/C cars with 300 lbs more weight.
The only stock NA setups that can drive on the street that I know of and running as fast or faster than me are spraying or have 1000lbs. LESS weight than me.
Oh and most "streetable" H/C setups I've seen are making 420-460rwhp. So what are you talking about?
You liked the sound of the ATI at idle? Mine sounds really bad at idle(like a Cement Truck), but smooths out when spinning up. I have yet to hear anybody saying otherwise till now..
From the way this post is going, I take it I'm either going to have to get a big turbo(s) or a big (F1) S/C. Sound about right?
People in front me tell me they hear the blower, people behind me tell me they hear the exhaust. But when I bust that surge valve open after 5 or 6 lbs. of boost, jaws just drop Myself included. That is the coolest sound ever!
This truck next to me asked me to do a quick blast so he could hear, which I oblieged and then turned into a gas station to fill up. Next thing I know two S/Ced foxes pull in cause they heard me. And my exhaust is loud as hell(LTs and cutout)! So even though inside the car I don't hear the blower so well when I get on it, people outside say they hear it well. Hope this helps.
Mike
Mike
I've noticed that the more boost I run the louder the whine gets. My D-1SC whines loud enough for me to hear it over my exhaust with the 3.85 pulley. My cars pretty damn loud too.
Nine Ball ran a 10.67 @ 128mph with a N/A 434, and this was with a full weight car. You have a BLOWN 422 and are still slower then he was...
Maybe I should clarify... a stock cube engine built heads / cam (in my experience) may make 400 RWHP. An FI stock motor should do more (even with the added weight of the SC kit). I thought anyone would realize that from the HP numbers I threw out.
Oh, and I don't see my 422 outperforming a big cube NA motor (which will have much higher compression and is optimized for NA) until I crank the boost. So far I'm only making 5 PSI to start and 7 or 8 PSI at peak RPMs. My motor is not optimized for peak power yet.
When will it be? When I can get enough money to properly feed it for higher boost and keep parts from breaking from the power/torque.
Hey Mike, you're in EFA aren't you? You think we can meet up sometime so I can check out your setup in person? BTW, I'm Raptor on the EFA board.
