what am i doing wrong?
Old May 14, 2008 | 10:16 AM
Rickys S/C Z28's Avatar
Default what am i doing wrong?
ok guys here the deal iv had high hope for my car and now that iv been to the track, dyno and just driveing around im kinda disappointed with it, not to bad but just not what i thought it would be, hear is the setup
2000 camaro z28
p1sc 6rib
epp blower cam
epp fmic
forged bottom end
60 lbs inj
stock 6.0 heads
vic jr
intake elbow
pacesetter long tubes
ORY
magnaflow
tune(great bu the way)
3800 stall
built A4
stock rear end with 3.08s
now from what i have read on here the car should be bad *** but it just seems like it laking, car went 11.70@120 and made 500/495 on the dyno(well did 450/405 but the dyno has been proved to show 10-13% lower numbers the most dynojets)
the seat of the pants dyno is great but the number just dont seem to be as good as others that iv seen on here, so what do yall think did i just have my goals set to hi? or what?? i wanted to see a 10.99 withthe car and its a long way from that.
so what can i do?
Old May 14, 2008 | 10:25 AM
98transguy's Avatar
is the car hooking at the track?what kind of tires u using?any suspension mods?
Old May 14, 2008 | 10:34 AM
rufretic's Avatar
You should be disapointed, that's a lot of work to run mid 11s. I bet there is more in it. How much boost are you running? How was your 60'? What is your race weight? You might be able to just change your blower pulley and put on better suspension/bigger tires and get in the 10s.
Optimus_Prime's Avatar
Originally Posted by Rickys S/C Z28
p1sc 6rib
There's your problem
Old May 14, 2008 | 10:41 AM
Superman09's Avatar
LS1Tech Sponsor
Upgrade to 8 rib F1A and 12-14 psi and you'll be much happier
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old May 14, 2008 | 10:50 AM
Disturbed Bird's Avatar
+1
and the fact you still have the factory 10bolt that thing is about to break.
Old May 14, 2008 | 11:35 AM
well guys im still mostly stock on the suspension part, i have LCA and SFC, and running MT ET Streets the radal, and i forgot i have a stock size crank pulley and a 3.20 headunit pulley, the car is makeing 6.5 psi of now, do you guys think the 6rib is killing me that much?
the car is as heavy as the day it came from chevy, i dont want to upgrade the head unit as of yet.........well i cant upgrade yet($$$$$$) i have a bmr adj TQ arm that i have not put on yet and bmr springs that still need to go on also
Old May 14, 2008 | 11:48 AM
99ssleeper's Avatar
...made 500/495 on the dyno(well did 450/405 but the dyno has been proved to show 10-13% lower numbers the most dynojets)...
Old May 14, 2008 | 12:07 PM
????????? what does that meen sir?
Old May 14, 2008 | 12:44 PM
GMLIFER's Avatar
Imo, that sounds pretty close. What was your 60'? Does it pull hard up top? Your gears couldn't be helping much for a 1/4 mile car. What size tire you running with?
Old May 14, 2008 | 12:50 PM
rufretic's Avatar
Yeah, your right on track with what you should run. If you want to go faster, you need to drop some weight and or add more boost. To add more boost your going to need to upgrade, 3.2 is already a small pulley so most likely your going to need a bigger head unit and a 8 rib set-up. Your better off where your at now until your ready to upgrade your suspension and 10-bolt.
Old May 14, 2008 | 01:22 PM
98transguy's Avatar
i think once u get some more suspension under the car ,maybe a better gear suited to what u are running probably around a 3.73,a little weight reduction.its possible u might hit your goal.it should def get u closer than u are now.other than that like the others have said time to upgrade the head unit and push some more boost through the motor.
Old May 14, 2008 | 03:37 PM
99ssleeper's Avatar
it means you are too concerned with the numbers game. it made 450/405 not 500/495.
Old May 14, 2008 | 04:45 PM
Schantin's Avatar
Ricky....your car is performing right where it should be on the current combo. 6PSI corresponds correctly to your current HP level. 1LB of boost adds around 20-22HP. You have the same heads (LQ9) and +1 cubic inch displacement compared to my 5PSI turbo car. We're putting out nearly identical HP. Nothing wrong w/ the engine or how its performing on the given boost level.
So, in my $0.02 heres your problem:
You have a mostly stock suspension car with 3.08 gears. A swap to 3.73's will shave upwards of 1/2 second off the 1/4 mile times alone. That and the suspension are why you're running such a high trap speeds vs 1/4 times. At 120mph the car can obviously hit the 10sec zone.....except you're not putting the curent power to good use. Also, between the forged engine, current fuel system + FMIC, and the built trans you could safely run 10PSI .
I give you 3 Choices:
Option #: The easiest way to go 10's is up the gear ratio and tune the suspension to cut sub 2.0 60' times.
Option #2: Install a smaller pulley to increase the boost....but you'll still be running 11's if you can't put it to the pavement!
Option #3: Put the car on a major diet. Guessing it's at least 3600lbs with all the options + stereo.
My $0.02....go with Option #1. I'm not in the process of installing a 9" rear in my car + slicks for nothing
Old May 14, 2008 | 07:56 PM
the car is a pig on the big end im going threw the traps at like 5k maybe 5500
Old May 14, 2008 | 07:58 PM
well that is not helpful
Old May 14, 2008 | 07:59 PM
im working on the gears and a 8in crank pulley we will see were she is at after that
and thanks for the guys that have given me help
Old May 14, 2008 | 09:15 PM
Jon@BruteSpeed's Avatar
LS1TECH Sponsor
I make 370 on the mustang dyno and run 11.30's. If you want to run numbers at the drag strip you need to set the car up for that. The 3.08 gears are killing you. Get some good shocks(if you haven't already) on there to transfer some weight. Don't know what your sixty foot times are but with your power mid 1.5's should not be that hard to get. What RPM are you going through the traps at??
__________________
95 Pontiac Formula- Stock engine with ATI Procharger, Moser 12 bolt w/4:30 gears, Rossler trans, Neil Chance 4000 stall, M/T ET streets, 10.914@ 121.90mph, 1.452 60ft. GMHTP November 2010 Feature Car. Check it out at:
https://www.motortrend.com/features/...ebird-formula/
http://www.youtube.com/watch?v=abZ1z...ature=youtu.be
Old May 14, 2008 | 09:40 PM
kp's Avatar
kp
Not to be a dick..
But six years ago I had a 100% stock engined fully loaded 2000 Z28, P1SC, hacked tuning with a HPP3 and MAF translator, 38lb injectors, ST3500 converter and ALL the emissions parts intact along with MAC headers WITH cats. Stock 3.23 rear with 16" ET streets on stock wheels. Absolutely no weight reduction at all, jack and spare were even in the car. Ran 11.30-11.40s @ 123 and I drove it every day. That was 476rwhp on a dynojet with the trans locked.
Seeing the big restriction in your setup is the blower you really need to spin the crap out of it or find a D1SC and upgrade to an 8 rib. But in the meantime you could work on your 60 foot some and try to be more aggressive with the tune, you will have a hard time hurting anything with a P1SC and a 6 rib..
Old May 14, 2008 | 11:15 PM
85mudblazin's Avatar
Originally Posted by kp
Not to be a dick..
How much boost were you running then??
