2000+HP LSX Pics
Old May 15, 2008 | 12:14 PM
Worm Boy's Avatar
Default 2000+HP LSX Pics
We have made 20 passes on our LSX block with the 106mm turbo pushing 2000hp. We have since then upgraded to the 114mm turbo in hopes of making over 2500hp but found out at the same boost levels we ran with the 106 to the 114 we ran out of fuel system and hurt a head gasket. We decided to pull the motor and check everything over after these 30 passes to see how this new LSX block was holding up. Well here are some pics of the bearings and block. Even making over 2000hp for right at 30 passes the bearings and block still look new. Just thought some of you would like to see this info.
Steven Fereday
Late Model Racecraft
713-466-9900
Latemodelracecraft.com
Old May 15, 2008 | 12:18 PM
Stang's Bane's Avatar
Steven, was there any extra prep work on the block??? IE filling the coolant passages etc??? Looks pretty good to me for holding up to hell!!!
Old May 15, 2008 | 12:24 PM
BigBronco's Avatar
I doubt that the block is grouted. This is good to see that everything is looking good. I do not think you guys have a dial bore gauge to let us know if the cylinders have moved any but everything looks to be squared away! Let us know what Pecos and Bryan @ LME say when ever you guys get it back!
Old May 15, 2008 | 12:25 PM
Reject's Avatar
commented on the tx section thread but wanted to again!
Old May 15, 2008 | 12:40 PM
Rickys S/C Z28's Avatar
ww!!!!!!!!!!!!!!1
Old May 15, 2008 | 12:59 PM
hellbents10's Avatar
LS1Tech Sponsor
Very nice, seems to be holding up very well.
Old May 15, 2008 | 01:37 PM
daniel6718's Avatar
awesome
Old May 15, 2008 | 02:17 PM
GoldRust's Avatar
LS1TECH Sponsor / 7 Second Club
Word from LME is that everything is pretty much staying put. The bores looked great. They are bumping the hone through it for good measure then slapping it back together
Old May 15, 2008 | 02:21 PM
Z06PSI's Avatar
That is good to hear. Maybe that will be the base for my next motor.
Old May 15, 2008 | 02:53 PM
BigBronco's Avatar
Very Excited to see it back together setting people straight!
Old May 15, 2008 | 03:18 PM
theblur98ss's Avatar
Looks good. I probably missed it somewhere but are you running 6 bolt heads? What gaskets?
Old May 15, 2008 | 04:13 PM
GoldRust's Avatar
Yes, we are running the ETP 265 6 bolt per cylinder with SCE copper gaskets
Old May 15, 2008 | 04:41 PM
GoldRust's Avatar
Here is a link to a little video from a stock suspension race in Hattisburg Ms.
http://www.youtube.com/watch?v=W-9xdWd0kes
Old May 15, 2008 | 04:47 PM
firehawk123's Avatar
looks good , i will order one soon
Old May 15, 2008 | 05:48 PM
z28adiction's Avatar
Who put together your short block LME? Looks great would never know it was under that much stress.
Old May 15, 2008 | 07:04 PM
GoldRust's Avatar
Yes LME builds all of our engines. They have been building my stuff for a long time.
Old May 15, 2008 | 07:13 PM
BigJls1's Avatar
hmmm.
Zombie incountered the same problem, bigger turbo at same boost requires more fuel.
For some reason my mind thinks it should be the oposite in the bigger turbo would be less backpressure alowing more exhaust gas to exit easier thus letting the piston and cylinder to stay cooler and needing less fuel to stay away from denotation land.
Old May 15, 2008 | 07:19 PM
PhatTonis's Avatar
Originally Posted by BigJls1
hmmm.
you also have to keep in mind that a larger turbo at same psi is flowing more air. larger opening requires more air to maintain the same pressure, so at same boost levels the larger turbo should generate more power
Old May 15, 2008 | 07:20 PM
GoldRust's Avatar
Well my injector duty cycle went from 82% to 94% at the same boost levels. I know one thing, that 114 mm billet turbo is a bad bitch
Old May 15, 2008 | 07:22 PM
GoldRust's Avatar
You sir are correct. More to due with volume of air. I am sure someone who knows about fluid dynamics can elaborate.
