oiling turbo
Old May 18, 2008 | 04:24 PM
cjg454ss's Avatar
Default oiling turbo
is there a kit or anything to get oil to your turbo and drrain to the pan, something universal would work. i searched and could find anything, i
Old May 24, 2008 | 06:09 PM
cjg454ss's Avatar
any0ne?
Old May 24, 2008 | 08:10 PM
dman's Avatar
http://www.racepartsolutions.com/products.asp?cat=105
Old May 24, 2008 | 09:17 PM
Websy21's Avatar
Basically build your own with simple fittings, etc.
Old May 25, 2008 | 12:07 PM
cjg454ss's Avatar
could you use brake line and bend it for a nice custom look to the turbo and then just use regular lines for the gravity feed drain?
Old May 25, 2008 | 12:27 PM
hellbents10's Avatar
LS1Tech Sponsor
Yes 1/4" brake line works great! Also SS gas pipe from the hardware store works good for a oil drain line.
Old May 29, 2008 | 07:11 AM
cjg454ss's Avatar
for the drain can tranmission rubber lines be used?
Old Jun 1, 2008 | 05:51 PM
cjg454ss's Avatar
ttt tt
Old Jun 1, 2008 | 07:52 PM
camarols1's Avatar
The drain should be -10 to ensure good flow, trans cooler line will be too restrictive.
Old Jun 9, 2008 | 05:44 PM
dman's Avatar
yes, -10 for T3 and T4 turbos. -12 for the big boys. any hose that can withstand heat and oil will work.
