Another low boost OFI pass
Old May 19, 2008 | 07:40 AM
cablebandit's Avatar
Default Another low boost OFI pass
I went to an import event and made one pass yesterday before my torque converter bolts came loose. I was on my old fuddle converter while my yank was being sent back for a restall.
3psi launch
1.55 60'
6.5x @ 105 1/8
10.17@138 1/4
7.5psi and 4000# raceweight.
I had intended to try 12-15psi but forgot to bump my eboost2 to the higher setting so i was just on wastegate but I was very pleased with the result on such low boost. Normally i would have retightened the tq conv bolts and made more passes but I was TIRED. The day before I had driven 300 miles round trip to participate in a moutain cruise which was awesome. The Koni DA shocks ride so much better than the QA1s i had and made my 4130# handle pretty darn well! Then i drove 280 miles roundtrip for the import event yesterday so I wanted to just tighten the bolts back up and come home at the end of the day with no more drama.
The ofi kit is still working very well. I am really happy with the car now as it is a good all around streetcar. Its not the best at anything but does several pretty good. I got a/c...dvd...overdrive...tbrake...and a 3.08 gear..Koni DAs...a little of everything which suits me just fine.
Old May 19, 2008 | 07:48 AM
TNTramair's Avatar
nice numbers...id be very happy with those type of numbers!!
Old May 19, 2008 | 08:52 AM
2001WS6Vert's Avatar
I'm waiting to see the high boost runs.
Old May 19, 2008 | 09:18 AM
hellbents10's Avatar
LS1Tech Sponsor
Nicely done indeed! Looking good with low boost.
Old May 19, 2008 | 09:28 AM
SPRAYED 01's Avatar
You are my hero!!
Old May 19, 2008 | 10:13 AM
SUPERBOOST's Avatar
My car and goals are very simular to yours,except I have a little smaller turbo and t tops.I would love to see your car sometime,its really cool. Do you ever go to the Canton cruise in on the third saturday of every month? Or let me know when you are going to make a few passes somewhere in the area sometime.It will be a while before I have my car sorted out.
Old May 19, 2008 | 10:24 AM
I try to make the cruise ins but with all the things going on around atlanta and family, i dont make them all.
I too am waiting on some high boost runs. The old fuddle was only dropping 500rpms on the shifts so it is actually working well at 7.5 psi but 15psi would blow right thru. prolly have to wait on the Yank to get back before I can throw some *** at it.
here is the 7.5 psi pass...its HD so slow video cards wont play it smoothly
http://cablebandit.net/videos/superadoVScablebandit.wmv
Old May 19, 2008 | 11:51 AM
DanZ28's Avatar
Very nice! You need to keep playing the end of that a little longer though .
BMR Tech's Avatar
Nice pass Jerry!! hope to see some REAL boost passes soon
Old May 19, 2008 | 11:55 AM
kp's Avatar
kp
3psi launch
1.55 60'
6.5x @ 105 1/8
10.17@138 1/4
Good to see you out having fun and no major issues, its a lot more fun to make some passes and enjoy the car than to push it hard and try to blow it up everytime at the track. Thats running pretty well for being turned down so far. Thats why I settle at running 9.0-9.50 instead of 8.50-9.0, thats an aweful lot of extra work and chance of hurting something just for half a click of a second hand on a watch
Old May 19, 2008 | 12:35 PM
Websy21's Avatar
Sweet, thats awesome........... I too would be happy and your goals/results are the same that I am shooting for too. I nice well balanced combo that does it all nicely while being as reliable as possible, hats off!
Old May 19, 2008 | 01:27 PM
Thanks guys.
KP, I want to push it much harder but just havent had the chance yet. Yesterday was an opportunity and I had planned to do 12-15psi on the next pass but those bolts werent tight enuff so thats how it goes. At least now everything feels "right" and not like its on the edge. I am driving it up to huntsville to the space museum and maybe after that i can hit the track again. I wont catch you or MM but I would still like to run a 9.3x all out.
Old May 19, 2008 | 01:58 PM
HUNTER02SS's Avatar
Nice Jerry. Tight converter bolts are a requirement when racing at the track.LOL.
Old May 19, 2008 | 02:16 PM
MIGHTYMOUSE's Avatar
when you get your yank back run all 6 bolts i have a new tci flexplate i can sell you that will help with that if needed.
what back tire? you think the rear will hold the load?
Old May 19, 2008 | 03:23 PM
i got a tci which is what causes the bolt probs. it sits closer to the rear engine cover and my normal bolts hit the rear cover bolts. i will be fine once i get the yank back...i had 6 bolts in it and had no probs.
Hunter, you might have mentioned that earlier
Old May 19, 2008 | 03:30 PM
HUNTER02SS's Avatar
Short memory!
Old May 19, 2008 | 07:00 PM
venom ws7's Avatar
WOW great numbers with such low boost and heavy car
CONGRATS.
Old May 19, 2008 | 07:21 PM
Darren P's Avatar
3psi launch
1.55 60'
6.5x @ 105 1/8
10.17@138 1/4
nice run
Old May 19, 2008 | 08:13 PM
onfire's Avatar
Coal Mining Director
Very nice Jerry! I get by with 3 bolts but use threaded bolts through the TC and use lock nuts on the back of them...so far so good.
Old May 19, 2008 | 08:29 PM
Sideways240sx's Avatar
wow, car is flyin for that boost. congrats on the runs.
Chris
