Well I Clicked "Commit to buy" on the Ebay Turbo
Old May 24, 2008 | 05:07 PM
  #41
presto_z's Avatar
here is the basic idea of how the kit runs.. i know there are better pics floating around..
Old May 24, 2008 | 05:19 PM
  #42
presto_z's Avatar
Originally Posted by ls1290
poor welding, crappy polished steel, thin weak flanges, and on and on.
yep these welds sure seem shitty to me
ohh and wow the flanges are thin
everysingle person who has actually seen the kits in person says how nice the pipes are and how nice and thick the flanges are are
everything in your post was pretty much wrong.. dont bash products until you have physically seen them.
i will agree the turbo is garbage but the pipes are not..
Old May 26, 2008 | 12:08 AM
  #43
TARZAN's Avatar
I have one of the kits, came in a couple weeks ago. I've been acquiring the rest of the parts to finish my setup. I must agree, as have all who have seen the kit. The welds, flange thickness, and the fact that even the ports are cleaned up a bit were all pleasant surprises. I intend on selling the turbo, and I'm not even using the downpipe (too small for my turbo). I intend on building a support bracket to help hold the turbo up, to reduce the chance of cracking. Also ordered the large intercooler from justintercoolers off of ebay and was pleased with the product as well. welds look good, ends are even nicely polished. If I have to do some drilling to the bolts holes on the headers, so be it...should be interesting.
-Will
Old May 27, 2008 | 06:25 PM
  #44
Monello's Avatar
Presto,
I just got my kits, looks great!
Flanges are VERY thick, and welds look nice.
Did you receive only 2 boxes? I got all the piping and turbo, but the Intercooler is missing =(. Did you get 3 boxes with your kit?
I need to contact the guy and find out where it is.
Old May 27, 2008 | 07:18 PM
  #45
Monello's Avatar
I was wiggeling the intake side of the turbo and it had side to side play in it. I am just going to buy a quality turbo from one of our sponsers.
Question is, can this turbo be fixed?
Old May 27, 2008 | 07:24 PM
  #46
frcefed98's Avatar
There will be some play until the center section is pressurized with oil, the "slack" will then be taken up. Normal. I wouldn't expect that turbo to last though.
Looks nice......looks.
Old May 27, 2008 | 07:30 PM
  #47
Monello's Avatar
frcefed98, when the turbo fails, can it cause any damage to the motor?
If Yes, i do not even want to take a chance using it. What do you think?
Found someone selling the same turbo on ebay for 300 bucks.
Frcefed98 would it be against the rules to post an ebay link to the turbo?
Old May 27, 2008 | 08:23 PM
  #48
Dunn's Avatar
Hope it works out for you guys, did the kit come with Vband clamps? Mine for the mustang didnt, and I had to grind the flanges that fit for the crossover.
The welds look good, so did mine, after a little bit of heat through them though, and you will see the true nature of how well the welds really hold.
Old May 27, 2008 | 08:36 PM
  #49
Rickys S/C Z28's Avatar
good luck with this kit,ill be checking to see how it works out
Old May 27, 2008 | 09:23 PM
  #50
Monello's Avatar
So did you end up ditching the kit or were you able to get the welds fixed?
Old May 27, 2008 | 09:29 PM
  #51
HitmanLSX's Avatar
I'm assuming you have to remove the A/C? Or no?
Old May 27, 2008 | 09:31 PM
  #52
slick1851's Avatar
Were going to see how this kit works out, if theres alot of people im sure it will just get cut up and use what worls.
Hes going to place some of the junk stuff with better qaulity parts along with the turbo
He wants 450whp with a turbo setup, not a head n cam..
  #53
slick1851's Avatar
Still have the AC...
Its not installed yet
Old May 27, 2008 | 09:52 PM
  #54
Dunn's Avatar
luckly found someone who was able to weld stainless, he said that overall the welds looked good, but were weak overall. He said if broke again in close to the same place, he would ditch the kit, it wouldn't be worth the repair.
Old May 28, 2008 | 08:23 AM
  #55
NemeSS's Avatar
so hows it coming along
Old May 28, 2008 | 08:52 AM
  #56
DRGnFLYZ28's Avatar
I like the looks & price of this kit. Can someone please do a step by step write up with pics!!?? I want to see dyno numbers with the turbo that comes with the kit.
Old May 28, 2008 | 09:50 AM
  #57
Monello's Avatar
The intercooler is in the mail. Should receive it on Friday.
I am starting to order the little stuff today.
Fans
Injectors
Fuel Pump
Couplers
V-Band Clamps
T-Bolt Clamps
Gauges
etc
Old May 28, 2008 | 11:15 AM
  #58
TARZAN's Avatar
Let me know if you find somewhere what sells V-band clamps in bulk or something....
Stock fans won't work?
-Will
Old May 28, 2008 | 02:11 PM
  #59
jkz06's Avatar
There is a good chance that if the turbo goes it could shoot parts in to the motor.
Old May 28, 2008 | 04:28 PM
  #60
frcefed98's Avatar
Yes posting ebay links to items that our sponsors sell i.e. turbochargers or turbo kits is against the rules.
If you have an intercooler in between the TB and the turbo i'd think the IC would catch most of the debris.....but you never know.....I wouldn't chance it....well maybe on my beater honda civic, but not my Formula.
A TC76 is under 1k from FI.com and will put down some serious power. It also has a 1yr unconditional warranty from turbonetics.
J
