Well I Clicked "Commit to buy" on the Ebay Turbo
Old May 28, 2008 | 06:21 PM
  #61
Monello's Avatar
This may sound stupid, but what is the difference between a T67 and T76?
They are both the same price on the FI.com website. Why wouldnt someone just go with a T76 if they can get it for the same price as a T67?
Old May 28, 2008 | 06:23 PM
  #62
Monello's Avatar
Originally Posted by TARZAN
Let me know if you find somewhere what sells V-band clamps in bulk or something....
Stock fans won't work?
-Will
I dont think the stock fans will work. I am going to be mounting my fans in front of the radiator instead of behind.
Im almost positive that the stock fans are pullers, and I need to use pushers if they are going to be mounted in front.
Also, Ive been trying to find a good deal on V-clamps but they all seem to be expensive. Let me know where you end up buying your clamps from.
Old May 29, 2008 | 12:09 AM
  #63
LS198Z28's Avatar
just bought one, been looking at them for the past 2 months
Old May 29, 2008 | 03:57 AM
  #64
TARZAN's Avatar
V-band clamp search begins....
-Will
Old May 29, 2008 | 02:03 PM
  #65
Monello's Avatar
Cheapest I have found is 18 bucks a clamp. They seem like they are quality clamps.
What have you found?
Old May 29, 2008 | 02:57 PM
  #66
TARZAN's Avatar
They're all over e-bay, but I haven't been able to find much on their quality or durability....
-Will
Old May 29, 2008 | 05:35 PM
  #67
presto_z's Avatar
make sure you get stainless vbands. cheaply priced aluminum ones will not hold up..
Old May 29, 2008 | 05:42 PM
  #68
jetlag's Avatar
Dang, so..$800 for the piping and crap turbo...sell that for a bit of money..buy a fancy $1000 turbo from a sponsor.... might be a good budget system!
Old May 29, 2008 | 06:09 PM
  #69
presto_z's Avatar
i just dropped mine off for the 2,000* jet hot coating today .. the owner of the shop said they are very well built. i can add him to the list of people who actually know their **** and are very impressed with them..
multiple sponsors on this site have seen the hot side piping of these kits and are very impressed with them
Old May 29, 2008 | 06:13 PM
  #70
frcefed98's Avatar
76=76mm
67=67mm
76 is a bigger turbo and has a higher output than a 67mm.
Old May 29, 2008 | 06:17 PM
  #71
Monello's Avatar
Thanks for clarifying that Frcefed =).
Presto what turbo are you using for your kit?
Also how many vband clamps did you end up buying?
I counted 6 smaller ends. Guessing 2.5 inch?
and 2 larger ends Guesing 3.0 inch?
Old May 29, 2008 | 07:46 PM
  #72
presto_z's Avatar
im still looking for another turbo, i know the one i want im just waiting till i find a price i wanna pay
as for the clamps
6-2.5" and 2-3"
btw be sure to get those pipes coated or wrap them
Old May 29, 2008 | 09:23 PM
  #73
Monello's Avatar
Presto, i bought the v-band clamps, 155 bucks for 6 clamps.
What BOV/Wastegate are you going with?
Old May 29, 2008 | 09:37 PM
  #74
presto_z's Avatar
PM sent
Old May 29, 2008 | 11:21 PM
  #75
Hennytime's Avatar
Originally Posted by frcefed98
76=76mm
67=67mm
the the t76 physically larger or just the internals? could a t76 directly fit on this setup? im interested in seeing the setup installed and running, but looks promising
Old May 30, 2008 | 11:34 AM
  #76
TARZAN's Avatar
I've got a GT45 that I'm going to be bolting on. It'll bolt up to the flange, we'll see if I have any clearance issues when its on the car....We're fabbing up some bracing to make sure the piping isn't left trying to support the weight of the turbo.
I'm also gonna wrap all the piping and use some DEI Silicone spray, for what its worth.
And on the v-bands, I'm not using any of the piping after the turbo, gotta get a larger downpipe, and I'm running a straight 3.5" back to a Borla bullet after the turbo.
-Will
Old May 30, 2008 | 04:39 PM
  #77
Todd157k's Avatar
Looking forward to your results. I was looking at those kits too.. and thinking the same thing as you.... just replace the turbos with good units. Post up some pics when you can and let us know how they really work.
BTW, I had a Vortech SQ that ate an impeller blade. It turned to paste before it ever entered the engine. No harm, no foul. (probably better CR.. lol)
Old May 30, 2008 | 09:10 PM
  #78
candlelit's Avatar
questions for those of you that has researched this turbo kit...
*those "headers" or whatever they are, is that what helps to keep the A/C? do you think they will last???
*are there any pipes that runs under the k member??? stock k member or tubular? relocated alternator??
I've previously traded a motor for a new Garrett turbo, so I'm really thinking about using this kit for the pipes. If the headers will hold up awhile & keep a/c, and of course steel is steel although the welds may not be the best, sounds like it's a decent deal to me.
Old May 30, 2008 | 11:53 PM
  #79
Websy21's Avatar
If you can see how the headers are routed you will understand more so. The turbo is mounted where the alt is and moved up above the idler pulley. So yes it keeps a/c, some of the really nice kits that don't keep a/c have the turbo mounted where the compressor is and the alt left alone.
I have the original PTK and the headers hold up, I can't couch for these but have 'heard' on here from a couple guys that they do indeed look to be up to the task but I am not sure on this.
With this kit you can use the stock K member, I did so with my PTK kit. There are no pipes that run under the k member either. There is a crossover pipe that runs from the passenger side and y's into the turbine housing. Many people claim that it is a low point, however I haven't drove my car yet but I don't find it to be low at all. Its tucked up nicely to the undercarriage and my SLP headers were allot lower than this piping. So I am not worried one bit. I here its worse for a M6 than a A4 in which I have so can't say much for the 6 speed crowd other than word.
To me 800 bucks is a steal, not even sure how they can do it for than, LOL Like mentioned many times though, toss the turbo and don't even attempt to try and use it.
Happy horsepower hunting
Old May 31, 2008 | 01:20 AM
  #80
NemeSS's Avatar
seems like the hotparts are now available without the turbo
