My DIY C6 mani turbo kit
Old 05-26-2008, 10:52 AM
WS6HUMMER's Avatar
Originally Posted by W8N2SQZ
Yeah all I had to do was cut a v groove in the motor mount tab on the K-member side.
Jer I will send the pictures right now.
Thanks Hunter! the car has been down at least 6 months now
GLenn
For both sides or just the drivers side?
Old 05-26-2008, 11:04 AM
ls2 bait's Avatar
man i wish i had the patience to do this. and the funds for that matter
Old 05-26-2008, 11:29 AM
7 Second Club
Phil99vette's Avatar
Lookin good.
Old 05-26-2008, 04:13 PM
W8N2SQZ's Avatar
i understand u are running a MANUAL scavenge pump?
running off the serpentine ?
more info and pics of manual scavenge pump plz
Yes the pump will run off the main belt. I sent pictures to Jeremy. Once he gets a minute to set them up, I will post them for you,
how much longer do you tink it will be till your done?
I hope by next weekend I will have the kit fully mocked up for a final fit. Once that happens, I will send it out to be coated. After that, assembly and oil feed and return and hook up the gates and boost controller. I would like to see it run in about two months. As long as I can find the time away from work
Driver side only. The passenger side fit but I cut off the black tab you see in the pictures above.
Thanks for the support everybody. Building your own kit is a process. The funny thing is, now that I have it welded up I already want to change how I ran some of the piping. I won't though because of cost and I want to try the system out to see what type of bugs pop up.
Glenn
Old 05-27-2008, 08:18 AM
SPRAYED 01's Avatar
Thats great!!!
Old 05-27-2008, 01:23 PM
1CAMWNDR's Avatar
Awesome. Simply awesome. Love the turbo placement and those brackets/flanges.
I'll be interested to see how the 2 bolt flanges work on the exhaust manifolds.
Old 05-28-2008, 10:18 PM
frcefed98's Avatar
More pics of Glenns set up: Oil pump for the turbo's. Glenn quote these pics to get the addy if you need em.
pulley with lock collar
pump bracket
pump bracket 2
pump mock up
pump mock up different view
and another view
Old 05-28-2008, 10:28 PM
NemeSS's Avatar
im digging that^^^^
any price available
very interested
Old 05-28-2008, 10:46 PM
LS1TECH Sponsor
DrTurbo's Avatar
Very nice indeed...you will like your TC66's
Old 05-29-2008, 12:36 AM
W8N2SQZ's Avatar
Hey thanks guys.
I'm gonna try to have the system mocked up on the car this weekend, but it is not looking good. So maybe next week.
Glenn
Old 05-29-2008, 05:56 AM
MUSTANGBRKR02's Avatar
Think you will have a problem with the brake line being so close on one of those first pics or is that just the camera angle?
Old 05-29-2008, 02:34 PM
  #32
W8N2SQZ's Avatar
You make a very good point and I was going to mention this. Guys, these pictures can be very missleading. Some of the system on the car has room, but the pictures make it look tight. While some of the stuff on the car doesn't seem that close but really is.
The brake lines are something I am a little worried about. I plan to use thermal wrap in critical areas so that it helps prevent a major issue.
If the brakes become spongy one the system gets hot, than I am going to re-run the brake lines.
Thanks for all the support and insight,
Glenn
Old 05-29-2008, 07:38 PM
  #33
ABeasst's Avatar
I would install braided stainless lines.
Old 05-29-2008, 08:39 PM
  #34
W8N2SQZ's Avatar
Good idea. I will look into it.
Thanks,
Glenn
Old 05-29-2008, 09:48 PM
  #35
1966goat's Avatar
Nice work
Old 05-29-2008, 11:38 PM
  #36
W8N2SQZ's Avatar
Thanks Goat!
Old 05-30-2008, 06:55 AM
  #37
Tiago's Avatar
good work!
Old 05-30-2008, 11:20 AM
  #38
smokinHawk's Avatar
curious to why you didnt use a truck manafold or fbody manafold on the driver side to avoid clearance issues?
Old 05-30-2008, 12:06 PM
  #39
WS6HUMMER's Avatar
x2 I'm just gonna use a truck manifold on the LH side.
Old 05-30-2008, 02:12 PM
  #40
Glenn
I would do that sooner than later personally, a few bucks there might possibly save you more if you lose your brakes.
Quick Reply: My DIY C6 mani turbo kit
