My DIY C6 mani turbo kit
Here is what I have been working on for the last few months. The kit has C6 manifolds on the driver and passenger side.
I am using a BMR turbo tubular K-member.
Everything is in mild steel and the intercooler pipes are stainless.
The only thing on this kit that I have to relocate are the cruise control, the coolant overflow, and the horn.
I have a manual pump that will be pulling the oil out of the turbos and returning it back to the motor.
I will have more pictures next weekend and a final mock up hopefully next weekend.
Let me know what you think.
Glenn
![](http://home.comcast.net/~jsbird1998/passtrbobrkt3.jpg)
![](http://home.comcast.net/~jsbird1998/passsdetrbo.jpg)
![](http://home.comcast.net/~jsbird1998/passsdechrgpipe.jpg)
![](http://home.comcast.net/~jsbird1998/pashdrfeed3.jpg)
![](http://home.comcast.net/~jsbird1998/pasdwnpipe3.jpg)
![](http://home.comcast.net/~jsbird1998/passdwnpipe.jpg)
![](http://home.comcast.net/~jsbird1998/pasdwnpipe2.jpg)
![](http://home.comcast.net/~jsbird1998/passsdegatemnt.jpg)
![](http://home.comcast.net/~jsbird1998/passsdetrbo3.jpg)
![](http://home.comcast.net/~jsbird1998/drvrtrbobrkt2.jpg)
![](http://home.comcast.net/~jsbird1998/drvrtrbobrktmntd.jpg)
![](http://home.comcast.net/~jsbird1998/drvrtrbomntd2.jpg)
![](http://home.comcast.net/~jsbird1998/drvrsdetrbo.jpg)
![](http://home.comcast.net/~jsbird1998/drvrsdefeed.jpg)
![](http://home.comcast.net/~jsbird1998/drvrdwnpipe.jpg)
![](http://home.comcast.net/~jsbird1998/drvdwnpipe2.jpg)
I have more to post, but something is acting up. I will try to get the rest later.
Glenn
Glenn
Glenn
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
Yes I do plan on using a scavenge pump and I have one mocked up. I will send those pictures to Jeremy so he can set them up so I can post them.
thanks for the kind words everybody.
Glenn
The pictures below are where the C6 manifolds have issues with the F-body K-member and where I had to grind and cut to make them work.
The driver side manifold hit the top of the motor mount so I had to grind the top of the motor mount like this.
![](http://home.comcast.net/~jsbird1998/drvrsdehit.jpg)
![](http://home.comcast.net/~jsbird1998/grndmtrmnt.jpg)
The driverside manifold also hit the motor mount perch, so I notched the K-member and ground down the manifold![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
![](http://home.comcast.net/~jsbird1998/drvrsidehttng.jpg)
![](http://home.comcast.net/~jsbird1998/cutmtrmnt.jpg)
![](http://home.comcast.net/~jsbird1998/grndC6drvrsdmani.jpg)
The passenger side is really close but it works. It looks like I will have to pull some of the wire loom apart and change or lengthen it so it does not hit the manifold. The unibody has a tab sticking out of it from the nut inside the frame where you run one of the k-member bolts through. I decided to cut the tab off, but don't have a picture of it. I think you will see what I mean in the picture below.
![](http://home.comcast.net/~jsbird1998/passsideclose2.jpg)
I should have more pictures later this week or next weekend.
Let me know what you guys think.
Glenn
Glenn
The turbos are TC66's. They are T4 flange with an E cover. They have H series comp wheels with F1 Ptrim turbine wheels.
For now, the intercooler is a 4" OBX type cooler. The intercooler pipes are 3" I will have more pictures of those later this week.
glenn
glenn
Yeah all I had to do was cut a v groove in the motor mount tab on the K-member side.
Jer I will send the pictures right now.
Thanks Hunter! the car has been down at least 6 months now![Barf](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_barf.gif)
GLenn
GLenn
