Hard Pipes and IAT?
Old May 30, 2008 | 05:03 PM
94m6Z28's Avatar
Default Hard Pipes and IAT?
where abouts are you guys or what are you doing with the IAT's? kinda curious as to where is the best location to place it
Old May 30, 2008 | 05:17 PM
theblur98ss's Avatar
I got the threaded IAT for a cyclone and put it a few inches before my TB. I just tapped the pipe. It's 3/8" NPT
Old May 30, 2008 | 05:30 PM
deadmanTA's Avatar
As long as it's after the IC. I reused the grommet 5/8 hole. Seen guys on here use the stockers up to 14 psi.
Old May 31, 2008 | 08:38 AM
ls1290's Avatar
Dumb Ass Vette Moderator
As long as the hole is drilled correctly, there no reason that it can not hold more. I know of several stock IAT sensors installed in steel pipes holding 20 to 22 pounds just fine.
Keith
Old May 31, 2008 | 09:02 AM
red83's Avatar
From: sneaking in your back door as you leave!/cartersville ga
weld a bung in it.................. get a threaded iat
Old May 31, 2008 | 10:36 AM
deadmanTA's Avatar
That's right zombie runs his up to 20 psi like this.
Old May 31, 2008 | 11:11 AM
94m6Z28's Avatar
so some have just drilled a hole in the pipe. no threading, and just plaed there stock IAT in it?, any trick to holding it in? hole size?
Old May 31, 2008 | 02:47 PM
deadmanTA's Avatar
Hole size is 5/8. drill straight as possible and don't let the bit wallow out any. Simply a perfect 5/8 hole, you don't want it loose. Reuse the stock grommet and sensor.
Old Jun 1, 2008 | 12:59 AM
94m6Z28's Avatar
there is a gromit in the rubber elbo? ill have to dig it out and look...if not would some silly cone work to hold it in as well or could that cause some weird heat soak or some thing
Old Jun 1, 2008 | 01:58 AM
TransAmcoupe98's Avatar
^ dumdumdum
Old Jun 1, 2008 | 08:10 AM
ss_girl's Avatar
I just drilled and tapped my pipe and got the threaded iat.
