Who has tested there turbo back pressure?
Old 06-02-2008, 09:07 PM
B18B1LS1's Avatar
Originally Posted by MADMAN
On our twin turbo mustang is made 35 lbs of boost and 48 lbs of back pressure at 1490 rwhp. This was on twin 91mm with true 4" exhaust dumping 4 ft from the turbos.
Is it normal to make "only" 1490 rwhp with twin 91's at 35 psi? Just curious on the rest of the combo I guess!
Jeffrey
engineermike's Avatar
That kinda' surprises me that the backpressure is that high with those two huge turbo's. Usually, the bigger the turbo in relation to the engine, the lower the backpressure (see also Old Geezer's data). Maybe it's a huge engine or spinning really high rpm. . .
Mike
Old 06-02-2008, 09:08 PM
B18B1LS1's Avatar
Originally Posted by DrTurbo
Diesel doesn't apply here....
Ha ha! That didnt take long! Its the only turbo vehicle I have running at the moment.
Old 06-02-2008, 09:10 PM
Folks, keep in mind that the cold-side is just as influential on backpressure as the hot side. Restrictive piping, restrictive intercooler, small TB, small compressor, or even a small air filter will a) reduce boost in the intake plenum and b) make the turbine work extra hard to spin the compressor in an effort to reach wastegate setpoint. Both of these make the E/I ratio worse.
Mike
Old 06-02-2008, 09:53 PM
LS1TECH Sponsor
DrTurbo's Avatar
Mike
Very true....also the fuel used. Meth and Alky will have a definite effect on backpressure reading as well.
Old 06-03-2008, 06:18 AM
LS1Tech Sponsor
MADMAN's Avatar
Jeffrey
No its not normal. After disassembling the motor we found we only had 7.3 to 1 compression and the cam selection was wrong. We are changing some stuff up to make it 9 to 1 and a new cam and we should see some changes.
__________________
www.madmanandcoracing.com
225-343-9029
Old 06-03-2008, 06:19 AM
LS1Tech Sponsor
MADMAN's Avatar
Mike
You need to come by and put your "engineer" eyes on it!!!!
__________________
225-343-9029
Old 06-03-2008, 06:36 AM
I'm afraid I'd get "turbo envy".
Old 06-03-2008, 09:17 AM
LS1TECH Sponsor
DrTurbo's Avatar
We plan to bring to the market a special "Blue Turbo pill" just for that. Turboagra
Old 06-03-2008, 11:22 AM
HydroStream6's Avatar
I assume this is measured after the turbo correct? Where would be the best place to check backpressure on a rear mounted setup?
Old 06-03-2008, 11:43 AM
LS1TECH Sponsor
DrTurbo's Avatar
BP should be measured after and before the turbo.
Old 06-03-2008, 08:36 PM
  #32
B18B1LS1's Avatar
Thats cool, I wasn't questioning you guys, just wondering what was up with it!
Old 06-04-2008, 01:02 PM
  #33
DeltaT's Avatar
How about 'Psiagra" instead?
Boost goes up and stays higher longer? Sign me up, but no SPAM!
Jim
Old 06-04-2008, 01:16 PM
  #34
7 Second Club
Phil99vette's Avatar
Is there a general rule of thumb for exhaust sizing to get a back pressure ratio of 1:1?
Old 06-04-2008, 01:18 PM
  #35
LS1TECH Sponsor
DrTurbo's Avatar
We use 1.25 X turbine exducer.
Old 06-04-2008, 01:19 PM
  #36
7 Second Club
So if the turbine exducer is 5" than you need something equal to ~6.25"?
Old 06-04-2008, 01:21 PM
  #37
LS1TECH Sponsor
DrTurbo's Avatar
Correct....of course thank goodness their is no turbo currently out yet that has a 5" exducer turbine....hehe
Old 06-04-2008, 01:30 PM
  #38
Fireball's Avatar
they would need one helluva v-band outlet too...that would become a restriction at that point since most thumpers use a std 5" setup...
Old 06-04-2008, 01:38 PM
  #39
7 Second Club
I know, just using round numbers so for a turbo with a 4" exducer you would need a 5" Exhaust, would that number assume the wastegate is vented internally or externally? How would that change the calculation?
Old 06-04-2008, 01:41 PM
  #40
LS1Tech Sponsor
hellbents10's Avatar
Depends on how soon the gate pipe is coming into the down pipe. Certainly there is a difference though because of the extra exhaust gas in the down pipe.
Quick Reply: Who has tested there turbo back pressure?
