Who has tested there turbo back pressure?
Just wondering if anyone has done their own testing of back pressure.
If so post up a quick review of your setup and boost pressure #s along with backpressure #s.
Thanks
Alex
Thanks
Alex
350 SBC with two .81A/R p-trim t-64s into 3" dynomax bullets
15 pounds at the compressor, is 20 in the exhaust.
I'm sure backpressure/boost ratio would worsen as boost goes up.
I use two boost gauges with recall to check pressure in different places.
1:1 is ideal. anything past 2:1 = effeciency loss.
I really wish more people would do this simple exercise and post results. It's a very good way to determine the true efficiency of a turbo system.
My basics: 388 LT1, AFR 210 heads, LT4 intake, 224/236-114 cam, T-76GTS (3" downpipe, 3.5" exhaust), Bell water/air intercooler.
With a 3.5" Hooker Aerochamber muffler, it made 680 rwhp at 21 psi boost and 48 psi backpressure.
With a 3.5" Magnaflow muffler, it made 695 rwhp at 17 psi boost and 34 psi backpressure. Set up like this, it ran 9.92 at 146 mph at full street weight.
I believe someone dyno'd a T76GTS versus an ST80 and posted the backpressure for those also.
Mike
Mike
You do, however, have to isolate the hot end from exhaust heat. I simply use a 6" piece of 1/8" pipe, then adapt to the small plastic tubing. The 6" piece of pipe isolates the tubing from the heat.
Mike
I really want to test mine also. I just ordered the new tc78mm from drturbo so im hoping that lowers my back pressure compared to the pte67mm. Oh ya and hopfully another 100hp or so.
Interesting read. Wish there was an easier way for me to route my downpipe...it snakes thru the stock k-member theres not much room for more than a 3"...guess I'll step it up to a 4" pipe after it clears the firewall and run a cutout or a 4" straight thru muffler turned down at the axle to help reduce the backpressure the closest I can.
![Lightbulb](https://ls1tech.com/forums/images/icons/icon3.gif)
26# boost, and 21# back psi, dump open. Closed, the BP went up 2 psi. 3" DP, and Dynomax muffs w/ 2.75" tailpipes out the back.
But, this is on a PT74GTQ, on a v-sicks Buick.. Only made 840 FWHP, 830 TQ...![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
The BP gauge was hooked at the base of the turbo, using a 3' length of copper tubing as a heat sink, then 2' of hose.
