STS Oil Restrictor/Pump Install How-To (Fix for oil in intake/exhaust pipes)
#44
1 Post
The resistor reduces voltage to the pump, thus the "low speed" pump operation. As stated earlier, the PCV pressure switch bypasses the resistor via the relays when it receives a signal that there is boost, causing the pump to swap to high-speed mode. By removing the resistor, the pump always runs on high speed, regardless of the PCV switch input.
#46
im not running the sts pcv system i have a catch can but i'm also clueless about whats going on when i take out that resistor i can definately hear the difference in the way the pump sounds but even with the resistor i have no smoke so as you said thats the best part
#48
https://ls1tech.com/forums/forced-induction/945232-who-eliminated-sts-pcv-system-used-catch-can.html
plus i dont wanna take credit for someone else's work
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
#49
What turbos were you running? I was using the stock STS GT67 "upgrade" when I added the restrictor. 4K miles later it was running strong with no problems. Interested to know what brand/size turbo you were using as well as the engine oil pressure feeding the turbine. This would be good info to add to this post, as the intent is to help STS owners, not cause turbine problems![/QUOTE]
The turbos are the ones that come with the Corvette C5 kit. The are Precision T3/T4 with a T04B compressor housing with a S trim wheel. The turbine appears to be a T3 4 bolt housing with a T31 stage 3 wheel. They are journal bearing. I called STS and of course the restrictor voided warranty. I called Precision and the said to only run a restrictor an the ball bearing turbos. They said the send them to STS and STS could send them back to them to be repaired. They will not sell you parts to do it yourself. I decided if I have to spend more money on the car I am going to upgrade. I am going to probably run twin mocal pumps and upgrading to ball bearing turbos. The car normally runs between 30 to 43 psi. I checked the lines and even rigged a pressure gauge up to make sure everything was ok. I have been a little disappointed with the oil return setup with the kit. If I had it to do all over I would install the mocal pumps immediately. I would have avoided alot of headache and wasted money. Your info is good by no means am I attacking your idea. It will help alot of people and helped me with the pump. I just wanted to put it out there. The bad thing for me was I had taken the car from Richmond to MIR for a track rental and wasted the turbos the first pass. I did the only thing I could do. I bought a 12 pack and kicked back. I am trying to get the car ready for a Nov 14th rental but it is not looking good. I need the turbos, a twin disc clutch, and the pumps. All that equals $$$$ and the play fund is low right now.
#50
1 Post
I think a twin Mocal setup will keep up no problems, though it'll vibrate the chassis without good rubber isolators between the pump and car body.
#52
#54
Really?!?!
As a Mechanical Engineer AND a Technical Trainer / Materials Developer for the classes I have taught (at: GM, Ford, and Volvo / Mack Trucks), I can say without reservations that STS' "instructions" are, at best, insufficient.
I had 2 different sets of STS instructions (LT1 96/97 & LS1 - both for F-Bodies), and I still had to figure out, by sense of smell, what every item in the kit did, and how they worked together.
Example - One item shown in both STS kit pictures (LT1 & LS1) was NEVER referenced in either sets of instructions, nor was it named in either of the two pictures! I had to call "Tech Support" to get this thing named and its function described.
Additionally, the instructions do not follow a logical sequence, nor do they explain the overall large processes before they begin.
I could go on, but suffice to say that not including a wiring diagram is just plain wrong! Oh, and the original idea to just let the IAT sensor "dangle" - Yeah, classic!
I got my STS kit installed in spite of the "instructions", and given the improvements listed by various LS1Tech board members over the years, I think we should welcome yet another 'fix' to this (very good and only slightly flawed) product.
#57
