Who eliminated the STS PCV system and used a catch can?
Old 06-27-2008, 10:00 PM
witry's Avatar
Default Who eliminated the STS PCV system and used a catch can?
ive heard alot about the sts pcv getting stuck and not working properly so before i put the whole kit on i want to eliminate the sts system and use a catch can how does that work and what do i need and if you got pics please post if possible thanks
Old 06-27-2008, 10:21 PM
Schantin's Avatar
Had it eliminated on mine. No issues in 2 years. No specific pics either.....and I can't take any since I just sold the entire STS kit off my car.
Sure someone else has pics for ya.
Old 06-28-2008, 12:58 AM
witry's Avatar
can you explain how you had it hooked up and what catch can you used
Old 06-28-2008, 02:02 AM
Silver_TransAm's Avatar
SCHANTIN why did you get out of the forced induction world? Got pics of how you did yours? I still need to do a catch can upgrade too, just keep over looking it all the time.
Old 06-28-2008, 04:03 AM
TransAmcoupe98's Avatar
What is the whole idea behind the catch can method?
Old 06-28-2008, 08:52 AM
sworaz's Avatar
When I did mine I put it inline where the pcv valve runs....first I eliminated the pcv valve and replaced it with a check valve. It keeps the oil/mist out of your intake. Revextreme (sponsor here) sells a very nice catch can. I think Norris MS does as well.
Old 06-28-2008, 08:59 AM
witry's Avatar
well from what i know it eliminates the whole electronic sts stuff and you use a mechanical system not electronic like sts with the inline pressure switch and check valve, all that stuff overtime i guess goes bad and doesnt work properly and the catch can always works and it seems to work alot better the the sts kit pcv system
Old 06-28-2008, 12:42 PM
John_D.'s Avatar
First of all, I converted to an LS6 valley cover and pcv, before I went turbo.
The setup with the turbo, is the front connection (from the valley cover) still has a pcv valve, and a small inline water/oil separator.
The back connection is capped with a breather. That way there's no direct line from the intake tract to the crankcase, but air can still enter when the pcv is pulling vacuum at idle.
Old 06-29-2008, 12:26 AM
Schantin's Avatar
OK, found an old pic that shows everything. Here's how mine was:
Stock PCV line routing from driver/passanger side to an AMW catchcan, then a small breather, and finally into the stock PCV valve. Worked like a champ. If you use a VENTED catchcan (which the AMW is not), then there is no need fo a breather. W/ a non-vented can and no beather you'll end out filling the catchcan w/ oil over time.
I elminiated the STS PCV shutoff valve and had no issues. The key is having the beather though. Using BOTH also isn't a bad idea as the breather will vent vapor and you'll have to wipe it off after driving (it'll have a small amount of oil residue on it).
I capped of the 2x small vacuum pots on the actual valve covers.
Anyhow, here's the pic:
To answer your other Q.....I decided to go back NA fo a couple reasons. Felt I had taken the STS to the limit for truly "streetable" drivabilityon the stock bottom end. I had it running very smooth, but it always required monitoring and adjusting to keep things good. I believe ANY FI system requires this. Anyhow, the wife and kids were tired of me always "pre-flighting" the car and maintaining it for the little amount of time it was driven. So, keeping the masses happy and going to a simple tune once and forget system.
Still trying a few things to get max power from the stock shotblock though.
Old 06-29-2008, 03:07 AM
Thats cool just wondering. Thanks for the pic. Good luck with the next build.
Old 06-29-2008, 08:49 AM
witry's Avatar
yeah thanks for the pic.... how did u hook up the breakther after the catch can?
Old 06-29-2008, 11:08 AM
Schantin's Avatar
A brass-T-fitting. Attached the breather to that.
Old 06-29-2008, 12:15 PM
witry's Avatar
ohh that makes sense and the breather was on the side goin to the catch can or out of the catch can?
Old 06-29-2008, 03:04 PM
Schantin's Avatar
I had mine coming FROM the catch-can. (Between the catch-can and the PCV valve).
Old 06-29-2008, 03:18 PM
Frost's Avatar
I dunno, I have tuned a lot of ATI systems that reguire nothing special except to add meth and change the SC oil...
Old 06-29-2008, 03:19 PM
sworaz's Avatar
So you had your pcv running from the side of the intake to catch can to breather then to the port by TB where the stock pcv goes? I take it you just have the other two ports on the passenger side valve cover capped off?
Old 06-29-2008, 08:48 PM
Schantin's Avatar
Yep, you got it....
Old 06-29-2008, 09:33 PM
sworaz's Avatar
Yep, you got it....
So is there any negative (or positive) to keeping the sts pcv gadget? (sorry don't know the technical name for it).
Old 06-29-2008, 09:41 PM
OUTLAWZ RACING's Avatar
Just delete it the sts thing sucks.
Old 06-29-2008, 09:43 PM
I feel your pain bro ! The wife is always saying why this and why that But I lover her for it because I just had a little one But the wife likes trail blazers alot sooo........ I may have two toys soon because she dosent know anything about the trailblazer SS!
Quick Reply: Who eliminated the STS PCV system and used a catch can?
