Cog setup???
Old Aug 13, 2003 | 01:09 AM
02BlackWS6's Avatar
Default Cog setup???
I thought LS1SPEED sold a cog setup for the ATI kit but when I emailed them a few weeks ago they said they don't sell a cog setup??? Even though their shop car has it. Does anyone make a cog system for the ATI kits?
Old Aug 13, 2003 | 10:06 AM
02BlackWS6's Avatar
Default Re: Cog setup???
Come on...no one knows if there's a cog setup out there???? I did a search, it only talked about LS1SPEED's setup. But they say they don't sell a cog setup now
Old Aug 13, 2003 | 10:49 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Why do you want cogs?
Do you have a 8 rib or 6 rib setup?
Do you know what cog belts cost?
Old Aug 13, 2003 | 02:43 PM
Blackbird's Avatar
how many psi are you looking to make?
I am going with sd-concepts 8 rib with spring tensioner setup.
they claim will spin the p1sc to it's max potential with no slip.
if your looking for 20psi out of a F1 it may not be the best option but if your looking for 12psi out of a D1 then it may be a good way to go?
Just throwing it out there. I have no real world experience with their stuff yet.
02BlackWS6's Avatar
John,
Why wouldn't i want a cog system? I only have a 6 rib setup and i want to run about 10psi. And no i'm not sure what a cog belt cost but it's got to be better than replacing a 6 rib belt every week. Someone on this forum has replaced over 26 belts on his D1SC. And i don't feel like dealing with that headache, i rather do it right from the start.
Old Aug 13, 2003 | 02:46 PM
02BlackWS6's Avatar
Blackbird,
I'm looking into the 8 rib setup as well. I just want to eliminate any slipping problems before i have them. I'm looking to run 10psi, maybe alittle more since i'm going with low compression and all forged internals.
Old Aug 13, 2003 | 02:50 PM
LS1Tech Co-Founder
Cog belts are over $90 each is my understanding.
Old Aug 13, 2003 | 02:53 PM
02BlackWS6's Avatar
$90?? Eeeeek!! Do they last a long time though? I would hope so
Old Aug 13, 2003 | 06:54 PM
Malicious's Avatar
Why has no one but crazy *** 6 second cars gone to a chain drive setup? I don't see anything other than added weight to add to it? Maybe its more expensive to get the pulleys made for chain? Saw an F2 on a stang with a chain drive, not gonna break that
Old Aug 13, 2003 | 07:19 PM
LS1Tech Co-Founder
Cost.
Old Aug 13, 2003 | 07:56 PM
Brick's Avatar
Why not just go with a turbo setup?? You won't have to worry about belt breakage or belt slippage.... Also, there isn't any stress on the crank like you have with a supercharger....
Do it right from the start and go with a turbo!!!
You'll be happy you did
Old Aug 13, 2003 | 08:06 PM
Brick's Avatar
Also if you do some research and talk to some people who have Cog belt driven superchargers you will find out that a Cog setup on a supercharger is NOT really designed for the street so I hope you don't plan on driving your car on the street much if any.........
Old Aug 13, 2003 | 08:18 PM
LS1Tech Co-Founder
90% of the problems that folks will have with a supercharger will be due to their tensioners not be adequate enough.
Until folks address that they really have not maxed our their setups.
My car has a custom tensioner that we can adjust to 250 ft lbs.
Old Aug 13, 2003 | 11:54 PM
KHShapiro's Avatar
PSJ,who made your Tensioner ?
Old Aug 14, 2003 | 01:14 AM
scottywheels's Avatar
You guys do not need a cog set up. Im running an F1 with 15 psi and an 8 rib set up and having no problems. I just changed my belt while changing the oil, and I have 2 months and 50 passes on it. Call me 203-415-4609 or pm me and I can help you with your pulley situation.
Old Aug 14, 2003 | 10:34 AM
LS1Tech Co-Founder
Chris from SS Racing (Znines)
Old Aug 14, 2003 | 09:47 PM
02BlackWS6's Avatar
Thanks everyone for all your help. I'll try the MMS pulley first and see what happens.
Scott,
If i have too much belt slippage i'll contact you for help. That's a nice setup you have.
Old Aug 14, 2003 | 09:49 PM
02BlackWS6's Avatar
I think sd-concepts makes an upgraded tensioner (6-rib) right?
Old Aug 15, 2003 | 01:07 AM
Blackbird's Avatar
yup
Old Aug 15, 2003 | 01:45 AM
MelloYellow's Avatar
Vortech didn't like a direct cog setup for their blower, but they do like secondary cogs. They like a tiny bit of slip to protect the blower from extreme things that could damage the headunit.
So they said.
