APS. litte things.
Old Jun 11, 2008 | 09:03 AM
Big Bird WS6's Avatar
Default APS. litte things.
what weight of oil should i use? is 0w50 bad? what spark plugs? what is a good collant supply? thanks
Old Jun 11, 2008 | 09:25 AM
Superman09's Avatar
LS1Tech Sponsor
why use that kind of oil? Ive never heard of anyone using that. Just run your regular 10w30 and you should be fine unless its some type of special situation or use. NGK TR6's are a good choice for plugs. Coolant, really whatever you want. I've heard to stay away from Dex-cool. I went with Prestone.
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old Jun 11, 2008 | 12:05 PM
idk, just that is what like the evo comes stock with. alot of turbo guys around here run it.
Old Jun 11, 2008 | 03:37 PM
Superman09's Avatar
LS1Tech Sponsor
hmmm, not to be a dick but you do not have an evo engine in your TA. I would run 10w30 for normal conditions, maybe different if you are strictly racing or live in an extra warm or cold environment.
__________________
Old Jun 11, 2008 | 03:47 PM
TNTramair's Avatar
10w30 oil here in my set up. +1 on what superman says also.
Old Jun 11, 2008 | 04:15 PM
you dick. just playin. well some guys use 5w40? what about that. i found this stuff called ENEOS. ever heard of it. W2W has a video on you tube with it.
Old Jun 11, 2008 | 04:22 PM
'Trust''s Avatar
Most use 10w30, 5w30, or 0w40. I don't know of any other mainstream used.
Old Jun 11, 2008 | 06:11 PM
barnat's Avatar
Default Evans
Now that ive read up on and used it personally EVANS coolant IS!!the best stuff out there exspespeciallyon a FI engine where blown head gastets are more prevalant because unlike regular coolant,,, Evans doesnt hurt the bearings if coolant gets down in the bearings with the engine oil !!!Being a former 87 GN owner!!, that had at least 20 blown head gaskets in the time i owned my car, Regular antifreeze is oK for stock engines THATS IT!!Ide go with a Evans coolant and water pump!! You cant gop wronge my man!!
Old Jun 11, 2008 | 06:15 PM
SPRAYED 01's Avatar
I use 0w-40 mobil one.
