APS car overheating
My only issue is how I am going to plug the trans cooler.
I do not have a APS kit, but do have a front mount turbo. My car gets hot with the AC on in city driving only. On the highway it is just fine. I wonder if I should try cleaning it really good. I have a lot of air in front and behind the radiator, and the only thing in front of it is a tranny cooler. If that does not work, I might try the LT1 radiator.
Keep us posted
How the hell where you to be able to tell the difference between the two?
If that's the way things happen man I would sue them too. I think some people are quick to blame a company when they screwed up. But them sending you the wrong one, that looks like your stocker, paying that much and not standing behind it is BS.
I normally don't say this but sue the **** out of them man.
EPP do you think the ron davis will fit the aps cars.You did a few aps cars already?
Water wetter by redline can also sometimes take temps down 10 degrees or so. I assume you have programmed your fans to come on low or have fan switch to run them continuously?
Remember you are still my hero JM and be watching what you do closely. But I think the steps mentioned above maybe all of them should do the job. My car is not going to be back to back tracked anyway see no reason to do back to back runs unless you are in bracket competitions.
I am hoping to finally give some ideas on this aps setup in regards to various areas soon. I am working like a beaver trying to get my 408 and aps installed. Figure a week or two tops as can put quite a lot of hours a day into this. Wish had some more help but at least have access to speed shop guy that is wizard with the little stuff .Today he helped me install the oil returns in the pan and fitting in the oil cooler port.
We moved that fitting down just slightly as aps has it so darn close to the tank angling ridge.
I guess every kit can use a bit of tweaking.
you ever get those upgraded ducts. and if you have or haven't please don't be shading about it is.
i just want to know if they are there so i can order them. Peter sucks and Customer Service.
thanks
Kinda like last months article in GM high tech of the car I built
