APS car overheating
To the topic, it would be nice if Peter at APS would chime in and give a little feedback, it is quite hot in Austailia, do they have any issues?
peter
It all comes down to airflow through the radiator. Whether it is debris in the fins of the condensor or something blocking the radiator like a bag that gets sucked up in there. If you interrupt the airflow through the radiator, you are going to have cooling issues.
For my old turbo kit with two pusher fans and one puller, with the LG racing radiator (800 bucks) and running 100% water with two jugs of 40 below coolant additive, the car still over heated with the AC on in stop and go traffic. When I say over heated, I mean it would shift between 220 and 230 degree's. Sometimes even higher.
So I am not sure about throwing a bunch of money at the cooling system is the answer.
Darren, I would look at the intercooler and see if can be mounted up front. The cost of tubing would be less than a radiator, pump, and coolant route.
Remember Speed Inc has a similar kit in regards to the turbos being mounted in the same fashion, but their intercooler is out front and not where the APS one is. I haven't heard of INTMD8T overheating with an iron LT1 block.
Just my .02,
Glenn
Just my .02,
Glenn
Be nice if APS was still on the boards.Peter used to be on here all the time and lately have not seen him at all. Would like his feedback on this stuff. Would like to know if the standard intake tubes have upgraded versions ready to buy yet. Maybe should be emailing APS directly the time difference for direct talking can be annoying.
Peter
So Peter what is your take on this overheating problem? And are the new intake ducts available for the standard system and will they solve the closing shut problem I plan on running 15 to 18psi likely if can go that high on my 408 with standard turbos.
As for possible help on this issue I was thinking to buy high volume new ls1 edebrock water pump and may consider different rad. But wondering why most of these rads like be cool or whatever are rated like 400hp? This last paragraphy is directed at posters in this thread.
http://s243.photobucket.com/albums/f...nat/Be%20Cool/
+ 1 for a new rad. im intrested in this thread as ill be grabbing the aps soon...
I have not messed with it at all
