APS car overheating
I'd say thats pretty good.
Of course, I am sure we need to first verify good working order of the thermostat, water pump, etc.
PS - Off topic - I was going to work, traveling down I-75 the other day and saw Don Gartlis out in his driveway doing a burnout in an old rail.....awesome sight.
Thanks, Rick
"Approximately 500F lower turbo temperatures. Eliminates the need for a turbo-timer, which allows the engine to run after the car is shut off in order to cool down the turbo and prevent oil and bearing damage.
Denser exhaust gasses drive the turbo turbine wheel more efficiently."
you want more heat IN the turbo.....and theres no way in hell a rearmount setup gives you denser gases and will drive the turbo more efficiently.id love to know where you copied that information from.
To the OP, I am over in the Wilmington area, I could try to meet up with you and give you a hand in sorting this out. The heat has been killer here lately!
-MODERATOR
for your overheating problem if it was me i would move the intercooler, i am not a big fan of putting it by the radiator, i learned my lesson with the tti street kit, i had horrible IAT temps and it ran kindof hot.
since you have an iron block those are a bit harder to cool, so you need as much air as possible going to the radiator.
sure it looks nice and factory like, but your IAT temps will be higher then the need to be and your car is going to run hot.
-MODERATOR
one problem though Smokin, in order for him to do that he would need to purchase a new front mount and run all new intercooler pipes. cause of APS's design, we cant just move the intercooler we have.
Is anyone else running hotter with the APS kit? If this is a trend, it would certainly be an intercooler covering the radiator issue.
